WinterHill Receiver Project
WinterHill
Features
• There are some restrictions when displaying the 4 TS on an RPi. A maximum of two H.265 signals may be displayed at the same time. It is recommended to use a PC to display the 4 TS, where there are no such restrictions. See the whpcviewer program in PC Software below.
Timeline
Version 0.1
Version 0.2
Version 1
Documentation
Raspberry Pi4 SD Card Building and Software Installation Manual (contains RPi4 software download details):
Media:WinterHill-RPi-Installation-Manual-3v20a-Rev1.pdf
Operations Manual - covers the Raspberry Pi and PC Control and Viewing utilities:
Media:WinterHill-Operations-Manual-3v20a-Rev4.pdf
Raspberry Pi Software
(November 2023) The main Raspberry Pi OS download page is now using Bullseye for legacy applications.
WinterHill requires Raspberry Pi Buster Desktop, without extra software which can be found here:
https://downloads.raspberrypi.org/raspios_oldstable_armhf/images/raspios_oldstable_armhf-2022-04-07/2022-04-04-raspios-buster-armhf.img.xz
  • Install software and reboot
PC Software
Control and Viewing Software for use on a PC. Fully described in the Operations manual above, with some details in the Readme files included with the software:
Multi VLC Viewer - displays the 4 channels received by WinterHill: File:whpcviewer-3v20d2.zip
--- New version June 2022 - fixes a problem with some non-English versions of Windows ---
Problems
H.265 display on the Raspberry Pi
(November 2023) The hardware codec is fine with some signals, but will not display others and then nothing at all. AnyHub mode is recommended, with no local display on the Raspberry Pi.
HDTV Monitors
VLC PC Firewall
If VLC does not display anything, even though the VLC title bar contains the correct information, it may be a firewall problem. Check the firewall settings for multiple entries for VLC and make sure that PRIVATE is ticked for all of them. PUBLIC may need to be ticked if you are using multicast IP addresses (starting 224-239).
VLC Initial Screen
To fix this:
Stop whpcviewer
Start a separate VLC window
Close the VLC window
Re-start whpcviewer
