Testing a HamTV Receiver using the Portsdown
Revision as of 14:01, 3 July 2024 by G8GKQ (talk | contribs) (Created page with "The Portsdown 4 system can be set to transmit a near-HamTV specification signal from a Pluto SDR on boot-up. ===Equipment Required=== * Raspberry Pi 4 with 1, 2 or 4 GB of m...")
Equipment Required
  • Raspberry Pi 4 with 1, 2 or 4 GB of memory. Not any other Raspberry Pi version.
  • A power supply for the Raspberry Pi.
  • A fast MicroSD Card of 8 GB or more capacity. SanDisk Ultra UHS-1 card recommended (the red one).
  • A genuine Analog Devices Pluto SDR with USB lead.
  • A PC for use during the set-up phase, with a MicroSD card reader and a network and internet connection.
  • A wired network connection for the Raspberry Pi during setup.
Setup Activities
  1. Configure the Pluto
  2. Load the operating system on the SD Card
  3. Run the automated build script on the SD Card
  4. Use a web browser to configure the Portsdown software to the correct settings
After these steps, the Pluto will start transmitting a 2 MS DVB-S signal on 2395 MHz every time the system is started up.
Configuring the Pluto
Loading the Operating System on the SD Card
Running the Build Script
Configuring for automatic transmission on 2395 MHz
