PicoTuner Ethernet Interface
PicoTuner photo: G6HFS
Updates, News and Issues
Try these versions if there are problems obtaining an IP address using DHCP: Media:PicoTuneWH_xwh0v3g_UF2.zip
2026-04-26: Added source code for ptwh0v3e.
Quick Start
Connect an Ethernet cable.
Overview
Required Equipment
Firmware Loading
Connect the USB port to a PC.
After the software has been loaded, the Pico can be put into BOOTSEL mode without having to press the Pico buttons. #Getting Into Firmware Loading Mode
Basic Operation
The Base IP Port is 9900.
Reboot.
Finding the IP Address
Ethernet MAC and Host Name
- E.g. 28:CD:C1:41:97:2E
- E.g. PicoTunerWH-41972E
DHCP
LNB PSU Output
Second LNB PSU Output
Working with a WinterHill
After startup, the first receiver is set to the QO-100 beacon and does the calibration.
Two seconds later, the second receiver is set to the beacon.
USB Serial Port Connection
On a PC:
- use Device Manager to find the COM port that has been allocated.
On an RPi:
- Type:
- ls /dev
- Type:
- Type:
- dmesg
- Type:
Type:
Type:
Add a new line:
- ACTION=="add",ENV{ID_BUS}=="usb",ENV{ID_SERIAL_SHORT}=="E660D441576B7F22",SYMLINK+="ttyPT1"
Save and exit
- CTRL-X then Y then ENTER
Uplug and plug the PicoTuner.
Type:
- ls /dev
On a PC:
On an RPi:
- find the ttyACM serial port that the Pico appears as and type:
PicoTuner Broadcast
Sequence 1294
Run time 1301s
Broadcast port 9997
Pico serial E6623C3767449A2E
Net hardware WIZnet W5500
MAC 28:CD:C1:44:9A:2E
Host name PicoTunerWH-449A2E
DHCP state Success
Lease remaining 2305s
IP address 192.168.77.196
NIM type FTS4334L
LNB supply X HI
LNB supply Y absent
Software ptwh0v3e-w5500.uf2
Mode WinterHill
Base IP port 9904
RX5 10496.700T DD0CW
RX6 10491.501T A71A
TS target RX5 192.168.77.247:9945
TS target RX6 192.168.77.247:9946
- netcat -kluv 9997
https://github.com/cyberisltd/NcatPortable
Click the green CODE button, then Download ZIP.
In a Command Box, type:
- ncat -luv 9997
| Reset: | [to@wh] reset=147 | clear any remote settings and reboot |
| Reboot: | [to@wh] reboot=258 | reboot, but do not clear any remote settings |
| BOOTSEL: | [ to@wh] bootsel=369 | go into software upload mode |
| Base IP Port: | [to@wh] bip=9908 | change the Base IP Port and reboot |
| Activity LED action: | [to@wh] tsflash=0 | activity LEDs are steady on when receiving, otherwise off |
- echo "[to@wh] bip=9908 tsflash=0" | netcat -uw1 192.168.77.196 9920 using the IP address of your PicoTunerWH
- echo [to@wh] bip=9908 tsflash=0 | ncat -uvi1 192.168.77.196 9920
- [to@wh] rcv=5 freq=10491500 offset=9750000 srate=1500 fplug=A (the LNB voltage generator parameter is optional - the parameter is OFF,LO,HI,LOT, HIT)
- [to@wh] rcv=6, freq=1304000, offset=0, srate=4000, fplug=A, VGX=HI
- [to@wh] VGX=LOT
To do this from an RPi, type:
- echo "[to@wh] rcv=5 freq=10491500 offset=9750000 srate=1500 fplug=A vgx=hi" | netcat -uw1 192.168.77.196 9920
- echo [to@wh] rcv=5 freq=10491500 offset=9750000 srate=1500 fplug=A vgx=hi | ncat -uvi1 192.168.77.196 9920
ptwh0v3e-w5500.uf2 is starting ======================================================================================================= ======================================================================================================= PicoTuner Dual Channel Digital TV Receiver - WinterHill mode - Version=ptwh0v3e-w5500.uf2 ======================================================================================================= +++ NIM_A FTS4334L initialised +++ ======================================================================================================= Waiting for Ethernet link - 0 Waiting for Ethernet link - 1 DHCP: starting DHCP: DISCOVER sent - My MAC 28:CD:C1:44:9A:2E - Transaction ID 2DCF9A2E DHCP: waiting for OFFER DHCP: OFFER of 192.168.77.196 received from 192.168.77.1 DHCP: REQUEST sent DHCP: waiting for ACK DHCP: ACK received DHCP: +++ SUCCESS +++ ============================================================================================================================================== PICOTUNER (WH mode) Version=ptwh0v3e-w5500.uf2 RunTime=17s BasePort=9904 MAC=28:CD:C1:44:9A:2E IP=192.168.77.196 DHCP=Success --------------------------------------------------------------------------------------------------------------------------------------------- RX STATUS CALLSIGN MER D FREQUENCY SR MODULATION FPRO CODECS ANT PACKETS %NUL NIMTYPE TS DESTINATION --------------------------------------------------------------------------------------------------------------------------------------------- 5 DVB-S2 A71A 10.3 5.6 10491.500 1500 QPSK 4/5 LN20 H264-MPA TOP 15801 2.9 FTS4334L 0.0.0.0 6 DVB-S2 A71A 10.2 5.5 10491.501 1500 QPSK 4/5 LN20 H264-MPA TOP 12488 2.8 FTS4334L 0.0.0.0 ============================================================================================================================================== Last command (0): [to@wh] rcv=2 fplug=a offset=9750000 freq=10491500 srate=1500
Source Code
ptwh0v3e was built by incorporating it into the examples in the WIZnet SDK (software development kit). https://github.com/Wiznet/RP2040-HAT-C
To install the WIZnet examples: git clone https://github.com/Wiznet/RP2040-HAT-C.git
I did have have an install script to build PicoTuneWH on a Portsdown, but that no longer works, possibly due to some of the Raspberry Pi archives being changed, so some experimentation will be required.
Some changes were required t
