PicoTuner Ethernet Interface
Revision as of 08:44, 23 July 2024 by G4EWJ (talk | contribs)
In progress . . .
The basic Pico module on the standard USB connected PicoTuner can be replaced by a WIZnet W5100S-EVB-Pico or W5500-EVB-Pico module.
The provides two receivers which can be controlled over the Ethernet connection and can send the received transport streams via the Ethernet connection, similar to a WinterHill.
Overview
PicoTuneWH is software for the BATC PicoTuner board that emulates a single NIM WinterHill and receives two signals at the same time, with commands and received data being sent over Ethernet.
There is no transport sream transfer by USB. A USB connection is not required.
It may be possible to use this software with OpenTuner (0.B).
