GB3CT - Caistor IO93UM
TX: 3404Mhz DVB-S2 h264 1M/s - 3/4 FEC
70cm RX: 436.5MHz 333k/s
(Not yet active) 13cm RX: 2435MHz Analogue FM & 2435MHz Digital 333Ks / 1Ms / 2Ms Note: This is a shared input and the default is digital switching to analogue when valid sync is detected on 2435Mhz FM.
A stream input is provided which will require you to register by Emailing your amateur radio licence document to gb3ct.repeater@gmail.com. This is required as your streamed video will be transmitted on GB3CT's 3404Mhz output and so is only available to licensed amateurs. Once registered, you will be provided with a pass key to access the stream input.
Caistor Top, Lincolnshire -IO93UM
