Portsdown 4 Signal Generator
Revision as of 13:20, 7 November 2026 by M0DNY (talk | contribs)
Using the Pluto as the Output Device
If you have Pluto selected as the output mode, you will need to calibrate it near the output frequency and power that you propose to use. So select those, MAKE SURE THAT NO SENSITIVE DEVICES ARE CONNECTED TO THE PLUTO OUTPUT, and press calibrate. You can then reconnect the output and the risk of power spikes is low after that. Frequency coverage is from 50 MHz to 6 GHz and the selectable output level is from a plus a few dBm down to about - 70 dBm (both frequency-dependent). The displayed output level is within about 1 dB on my 2 Plutos, and is corrected for the Pluto's frequency response. It is worth rebooting the Pluto (from the settings menu) before and after using it with the signal generator for accuracy and reliability.
Notes:
  • The Pluto calibration produces a pulse of up to 10 dBm.
  • If you have used the Pluto to transmit SSB or DATV since switch-on, it will need rebooting for use with the Sig Gen (either just the Pluto or the complete Portsdown with Pluto) to clear out the old settings
  • The Pluto signal has a spurious 4 MHz below it at about -45 dB and 3 others (2 MHz below, 1 MHz below and 2 MHz above) at about -55 dB. Spectrum at 0 dBm 437 MHz shown below.
The 5th Harmonic from the Pluto can also be used as a weak signal source for testing Microwave Receivers up to 30 GHz. Simply select Pluto 5th Harmonic as the output device. The output level is very low (typically max -33 dBm at 10 GHz) and is not calibrated. Again, there are spurii at - 4MHz (-27 dB), -2 MHz (-28 dB), +2 MHz (-46 dB) and +4 MHz (-40 dB). The spectrum below is at 10368 MHz.
Credits go to Alberto Ferraris IU1KVL (of Satsagen fame) for his plutotx software and to Robin Getz for his comments on that software. Thanks also to Colin G4EML for doing the initial investigations on Pluto 5th Harmonic mode.
Using the LimeSDR Mini as the Output Device
A LimeSDR Mini can be used as an output device. The frequency range is 50 MHz to 3500 MHz and the level from about +15 dBm (below 1500 MHz) to -40 dBm. The LimeSDR must have stock firmware loaded (Version 1.30, not LimeDVB). Use of the LimeDVB firmware generally results in a lower level output at 1 MHz below the set frequency.
Note that the LimeSDR Mini does require calibration before it can be used and the calibration spike can be up to +15 dBm even if the output level is set to be very low.
Using the DATV Express as the Output Device
Similarly, a DATV Express board can be used as an output device. The frequency range is 70 MHz to 2450 MHz and the level from about +10 dBm to -30 dBm. No calibration is required and you can apply 333kS QPSK modulation to check PA linearity.
Using an ADF4351 Module as the Output Device
To use an ADF4351, it needs to be connected to the GPIO pins as specified here [url]https://wiki.batc.org.uk/Portsdown_4_GPIO_Connections[/url]. It will cover from 35 MHz to 4.4 GHz, but only has 4 output levels, 3 dB spaced, around -5 dBm.
Using an AD9850 DDS Module as the Output Device
The AD9850 is a DDS integrated circuit from Analog Devices. With a 125 MHz (or lower) clock it will generate frequencies up to half the clock frequency. It has a constant level output and needs filtering to remove aliases above the desired frequency. A number of modules using the device are available from eBay.
To use the AD9850, the clock frequency needs to be entered into the settings on the Signal Generator. The Data Clock needs to be connected to RPi GPIO pin 29, the Data Line to RPi GPIO pin 31 and the FQ_UD line to RPi GPIO pin 8. The parallel data lines need to be hardwired into serial data mode.
Using an Elcom Microwave Source as the Output Device
The software will also drive an Elcom Microwave source within its operating range somewhere between 10 GHz and 14 GHz (depending on the model). Output level is fixed (generally at around +10 dBm). More information can be found on the Elcom modules here https://wiki.microwavers.org.uk/24_GHz#Elcom_synthesisers.
Using an NORT Synthesized Local Oscillator Microwave Source as the Output Device
The software will also drive a NORT Synthesized Local Oscillator Microwave source within its operating range somewhere between 10 GHz and 14 GHz (depending on the model). Output level is fixed (generally at around +14 dBm). More information on the NORT SLO modules can be found here https://wiki.microwavers.org.uk/Nort_SLO. Pin connections: SPI Clock 29, SPI Data 31 and SPI Latch Enable 8.
Controlling an ADF4135-based Synthesizer
The Portsdown 4 signal generator can also control an ADF4135-based Synthesizer. Pin connections: SPI Clock 29, SPI Data 31 and SPI Latch Enable 8.
Controlling the CMT2119A MicroSynth
Support for G4EML's MicroSynth (using the CMT2119A synthesizer IC) has been added to the Portsdown 4 Signal Generator. Connect the Clk to GPIO pin 29 (Portsdown standard interface pin 8) and the Data to GPIO pin 31 (Portsdown standard interface pin 9). Full details on this tiny 160 MHz to 1297 MHz synth with on-chip frequency memory here https://github.com/g4eml/MicroSynth. Thanks to Colin G4EML for doing all the hard work on this one.
