The Muntjac SDR
Revision as of 19:10, 25 March 2026 by G4EWJ (talk | contribs)
The Muntjac SDR was designed by Brian G4EWJ based on the same dual band AT86RF215 RF chip as the commercially-available CaribouLite SDR.
It is a transmit-only SDR for DVB-S2 DATV on 13cm (QO-100) and 70cm, which uses an RP2040 micro-controller to provide a USB interface to the Portsdown 4.
The 75 x 30mm board will come without SMA connectors, so that it can optionally be wired into a system for maximum flexibility. Long thread types are recommended.
Specifications
Muntjac Performance
19 +4.8 dBm +3.7 dBm
18 +4.0 dBm +2.8 dBm
17 +3.0 dBm +2.1 dBm
16 +2.1 dBm +1.2 dBm
14 +0.1 dBm -0.5 dBm
13 -0.9 dBm -1.4 dBm
12 -1.9 dBm -2.5 dBm
11 -2.6 dBm -3.3 dBm
9 -4.7 dBm -5.3 dBm
8 -5.7 dBm -6.3 dBm
7 -6.4 dBm -7.3 dBm
6 -7.4 dBm -8.3 dBm
4 -9.4 dBm -10.3 dBm
3 -10.2 dBm -11.1 dBm
2 -11.2 dBm -12.1 dBm
1 -12.2 dBm -13.1 dBm
Preparing for Use
Another Boxing Idea
The Hammond 1550P can be used by cutting slots into box and dropping in the Muntjac-4 board vertically.
IQ Calibration of the Muntjac
Poor IQ balance in an SDR can cause a carrier to be transmitted at the centre frequency of a DATV transmission.
