The Muntjac SDR
Revision as of 20:24, 25 March 2026 by G4EWJ (talk | contribs)
The Muntjac SDR was designed by Brian G4EWJ based on the same dual band AT86RF215 RF chip as the commercially-available CaribouLite SDR.
The 75 x 30mm board will come without SMA connectors, so that it can optionally be wired into a system for maximum flexibility. Long thread types are recommended.
Specifications
The ouput power of the Muntjac is set by a gain parameter in the range 0 - 20, with each step being nominally 1dB and power zero being -15dBm. The shoulders on the output spectrum are always greater than 30 dB down, and are better than that at lower output powers. Approximate output power is shown in the table below.
Muntjac Performance
19 +4.8 dBm +3.7 dBm
18 +4.0 dBm +2.8 dBm
17 +3.0 dBm +2.1 dBm
16 +2.1 dBm +1.2 dBm
14 +0.1 dBm -0.5 dBm
13 -0.9 dBm -1.4 dBm
12 -1.9 dBm -2.5 dBm
11 -2.6 dBm -3.3 dBm
9 -4.7 dBm -5.3 dBm
8 -5.7 dBm -6.3 dBm
7 -6.4 dBm -7.3 dBm
6 -7.4 dBm -8.3 dBm
4 -9.4 dBm -10.3 dBm
3 -10.2 dBm -11.1 dBm
2 -11.2 dBm -12.1 dBm
1 -12.2 dBm -13.1 dBm
Preparing for Use
Another Boxing Idea
The Hammond 1550P can be used by cutting slots into box and dropping in the Muntjac-4 board vertically.
Monitoring Muntjac Operation
To see the live log output from the Muntjac driver on the Portsdown (muntjacsdr_dvb) when it is running, log into the Portsdown with ssh and type:
nc -kluv 9979
Muntjac LEDs
There is a main LED near the button and an LED near each SMA socket.
The main LED blinks HI in morse (.... ..) at power up. This is for software version 1v0b. Later versions will blink 'MJ' and the last letter of the software version.
IQ Calibration of the Muntjac
Poor IQ balance in an SDR can cause a carrier to be transmitted at the centre frequency of a DATV transmission.
