The Muntjac SDR
Revision as of 16:54, 26 March 2026 by G4EWJ (talk | contribs) (→‎Muntjac LEDs)
The 75 x 30mm board will come without SMA connectors, so that it can optionally be wired into a system for maximum flexibility. Long thread SMA types are recommended.
The optional user-fitted ADE-30+ mixer is shown, which can be used for experiments on other bands. DATV is generated on the high band and mixed with the harmonic of a carrier on the low band.
Specifications
The ouput power of the Muntjac is set by a gain parameter in the range 0 - 20, with each step being nominally 1dB and power zero being -15dBm. The shoulders on the output spectrum are always greater than 30 dB down, and are better than that at lower output powers. Approximate output power is shown in the table below.
Muntjac Performance
19 +4.8 dBm +3.7 dBm
18 +4.0 dBm +2.8 dBm
17 +3.0 dBm +2.1 dBm
16 +2.1 dBm +1.2 dBm
14 +0.1 dBm -0.5 dBm
13 -0.9 dBm -1.4 dBm
12 -1.9 dBm -2.5 dBm
11 -2.6 dBm -3.3 dBm
9 -4.7 dBm -5.3 dBm
8 -5.7 dBm -6.3 dBm
7 -6.4 dBm -7.3 dBm
6 -7.4 dBm -8.3 dBm
4 -9.4 dBm -10.3 dBm
3 -10.2 dBm -11.1 dBm
2 -11.2 dBm -12.1 dBm
1 -12.2 dBm -13.1 dBm
Preparing for Use
Another Boxing Idea
Muntjac LEDs
Monitoring Muntjac Operation
To see the live log output from the Muntjac driver on the Portsdown (muntjacsdr_dvb) log into the Portsdown with ssh and type:
nc -kluv 9979
Lack of Calibration Spikes
IQ Calibration of the Muntjac
The AT86RF215 chip does an IQ balance as part of its self calibration before transmitting, but it doesn't always do the best job. Fortunately there are registers in the AT86RF215 which can be adjusted to improve the local oscillator suppression.
