The Muntjac SDR
Specifications
Preparing for Use
Another Boxing Idea
Before updating the Portsdown, if the Muntjac is connected to the Portsdown, disconnect it.
Make sure that you have the latest Portsdown version using Menu3 and 'Check for Update'
When that has completed, check for update again and select the DEV update in red.
First Transmission
If you're not familiar with the Portsdown, set the lines starting 'Modulation', 'Freq' and 'Easycap' as shown and enter your callsign via 'Menu 3' and 'Set Call, Loc & PIDs'.
Press 'Transmit' and after a second or two, the Muntjac main LED near the buttons will start double blinking off and the LED near the high band SMA will light steady.
LEDs
To see the live log output from the Muntjac driver (muntjacsdr_dvb) on the Portsdown, log into the Portsdown with ssh and type:
nc -kluv 9979
Lack of Calibration Spikes
IQ Calibration
The AT86RF215 chip does an IQ balance as part of its self calibration before transmitting, but it doesn't always do the best job. Fortunately there are registers in the AT86RF215 which can be adjusted to improve the local oscillator suppression.
Output Filtering
Frequency Accuracy
The AT86RF215 has an externally connected TXCO, with a temperature stability of 0.5ppm and initial accuracy of +/- 2ppm. The high band frequency output should be within a few kHz of nominal.
Problems
The Muntjac may not be seen as a USB COM port when connected to a USB3 hub. The USB3 connections on the RPi4 are not a problem.
