The Muntjac SDR
Specifications
Preparing for Use
Another Boxing Idea
Before updating the Portsdown, if the Muntjac is connected to the Portsdown, disconnect it.
Make sure that you have the latest Portsdown version using Menu3 and 'Check for Update'
When that has completed, check for update again and select the DEV update in red.
LEDs
First Transmission
nc -kluv 9979
Lack of Calibration Spikes
IQ Calibration
The AT86RF215 chip does an IQ balance as part of its self calibration before transmitting, but it doesn't always do the best job. Fortunately there are registers in the chip which can be adjusted to improve the local oscillator suppression.
Output Filtering
Frequency Accuracy
The AT86RF215 has an externally connected TXCO, with a temperature stability of 0.5ppm and initial accuracy of +/- 2ppm. The high band frequency output should be within a few kHz of nominal.
Problems
