The Muntjac SDR
Specifications
Preparing for Use
Another Boxing Idea
The Muntjac is included in the latest Portsdown 4 software, so make sure that your Portsdown is up to date using Menu 3 and 'Check for Update'. If the Muntjac is connected to the Portsdown, disconnect it before updating.
LEDs
First Transmission
nc -kluv 9979
Lack of Calibration Spikes
IQ Calibration
The AT86RF215 chip does an IQ balance as part of its self calibration before transmitting, but it doesn't always do the best job. Fortunately there are registers in the chip which can be adjusted to improve the local oscillator suppression.
Output Filtering
Frequency Accuracy
Problems
