The Muntjac SDR
Specifications
Preparing for Use
Another Boxing Idea
LEDs
First Transmission
nc -kluv 9979
Lack of Calibration Spikes
IQ Calibration
Output Filtering
Frequency Accuracy
The plots below show the effect of the power setting on the level of the shoulders. Shoulders are generally lower on 437MHz for the same power setting.
Problems
