The Muntjac SDR
Specifications
Muntjac Performance
19 +4.8 dBm +3.7 dBm
18 +4.0 dBm +2.8 dBm
17 +3.0 dBm +2.1 dBm
16 +2.1 dBm +1.2 dBm
14 +0.1 dBm -0.5 dBm
13 -0.9 dBm -1.4 dBm
12 -1.9 dBm -2.5 dBm
11 -2.6 dBm -3.3 dBm
9 -4.7 dBm -5.3 dBm
8 -5.7 dBm -6.3 dBm
7 -6.4 dBm -7.3 dBm
6 -7.4 dBm -8.3 dBm
4 -9.4 dBm -10.3 dBm
3 -10.2 dBm -11.1 dBm
2 -11.2 dBm -12.1 dBm
1 -12.2 dBm -13.1 dBm
Preparing for Use
Another Boxing Idea
LEDs
First Transmission
nc -kluv 9979
Lack of Calibration Spikes
IQ Calibration
Output Filtering
Frequency Accuracy
Programming the Microcontroller on the Muntjac
1. Locate the latest compiled firmware file 'muntjac4_pico-1v**.uf2' which will be found here https://github.com/davecrump/portsdown4/blob/master/src/muntjac/muntjac4_pico-1v0b.uf2 and save it to your desktop.
2. Hold down the BT button (the one nearest the SMA sockets) on the Muntjac while connecting it to your PC using its USB port. The Pico Muntjac appears as a USB disk drive on your PC.
3. Copy the .uf2 file onto the USB drive. The Muntjac will recognise the file and immediately update its firmware, reboot and the PC should recognise a new USB COM device. The main LED on the Muntjac will blink as it reboots. This will be 'HI' for firmware version 1v0b and "MJ" plus the last letter of the firmware version for later versions of the firmware.
4. Disconnect the Muntjac from the PC and connect it to the Portsdown. Make sure that the Muntjac is selected as the Output Device and then Select M2, Info. The Muntjac firmware version will be displayed along with the Muntjac Flash ID.
Alternative Method for Programming the Microcontroller
There is an alternative method of making the Muntjac appear as a USB drive, which may be useful if you've built the Muntjac into a box and cannot easily get to its buttons.
1. Plug the Muntjac into a PC and it will appear as a COM port. Note that this may not work through a USB3 hub.
2. Find the COM port number in device manager and open a terminal session to that COM port at 1200 baud with a program such as putty.
3. The COM port will disappear and the Muntjac will then appear as a USB drive.
4. Proceed with step 3 in the section above.
Note that this depends on the software already in the Muntjac being configured to do this. This approach would not work on a blank Raspberry Pi Pico board, which uses the same RP2040 microcontroller as the Muntjac.
Problems
Sometimes a cpu on the Raspberry Pi goes to 100% usage, in contest numbers, testcard or IPTS modes.
