Portsdown Band Viewer
The "Band Viewer" software is included with the Portsdown 4 and Portsdown 2020 and can be used to provide a basic spectrum display of band occupancy using the receive section of a LimeSDR, Pluto (Portsdown 4 only), Airspy R2 or RTL-SDR. It only works with the specified SDRs and the 7 inch screen (or the DSI-connected 5 inch screen), not the GPIO-connected 3.5 inch screen.
SDR | Frequency Coverage | Span Widths | Notes |
LimeSDR | 30 MHz - 3.5 GHz | 500 kHz, 1, 2, 5, 10, 20 MHz | LimeSDR Mini, LimeSDR USB or LimeNET Micro |
Pluto | 70 MHz - 6 GHz | 2, 5, 10, 20, 50 MHz | Portsdown 4 only |
Airspy R2 | 24 MHz - 1.7 GHz | 1, 2, 5, 10 MHz | Only Airspy R2 supported |
RTL-SDR | model-dependent | 1, 2 MHz |
Frequency
The centre frequency can be directly entered from the keyboard (selected from the Settings menu) and a number of programmable presets are available. The centre frequency can be shifted down or up by 10% of the span width by using the left and right buttons on the main menu. The presets can be configured fronm the Mode, Set Config, Set Freq Presets Menu. Stored frequency and presets are specific to each SDR type.
Level Display
Although the display is calibrated over 80 dB of dynamic range, only about 50 dB is usable. The Lime gain can be adjusted from the settings menu to optimise the display. Careful screening and grounding of the LimeSDR can produce a reduction in the noise level. There are a number of spurious signals that are visible in the passband; this is a limitation of using the LimeSDR.
Measurements and Recording
Resolution
Known Bugs and Limitations
Some display corruption of the button text occasionally occurs during marker operation. This seems to be limited to the areas of text around the display and is not critical.
Exit
To exit back to the Portsdown, select the System Menu. The Viewer can also be restarted from here.
Acknowledgements
