Portsdown Band Viewer
Revision as of 15:02, 21 November 2022 by G8GKQ (talk | contribs) (→‎Level Display)
The "Band Viewer" software is included with the Portsdown 4 and Portsdown 2020 and can be used to provide a basic spectrum display of band occupancy using the receive section of a LimeSDR, Pluto (Portsdown 4 only), Airspy R2 or RTL-SDR. It only works with the specified SDRs and the 7 inch screen (or the DSI-connected 5 inch screen), not the GPIO-connected 3.5 inch screen.
SDR Characteristics
SDR Frequency Coverage Span Widths Notes
LimeSDR 30 MHz - 3.5 GHz 500 kHz, 1, 2, 5, 10, 20 MHz LimeSDR Mini, LimeSDR USB or LimeNET Micro
Pluto 70 MHz - 6 GHz 2, 5, 10, 20, 50 MHz Portsdown 4 only
Airspy R2 24 MHz - 1.7 GHz 1, 2, 5, 10 MHz Only Airspy R2 supported
RTL-SDR model-dependant 1, 2 MHz
Starting the Software
BandViewer can be selected from Portsdown Menu 2, BandViewer. The BandViewer for specific SDRs can also be selected from Menu 2, Test Equipment. On selection of the generic BandViewer button, the software checks for the presence of the SDRs in the order: Lime, Airspy, Pluto, RTL-SDR. It uses the first SDR that it finds, or displays an error message if it cannot find an SDR.
Frequency
The centre frequency can be directly entered from the keyboard (selected from the Settings menu) and a number of programmable presets are available. The centre frequency can be shifted down or up by 10% of the span width by using the left and right buttons on the main menu. The presets can be configured fronm the Mode, Set Config, Set Freq Presets Menu. Stored frequency and presets are specific to each SDR type.
Level Display
Measurements and Recording
Resolution
Known Bugs and Limitations
Some display corruption of the button text occasionally occurs during marker operation. This seems to be limited to the areas of text around the display and is not critical.
Exit
To exit back to the Portsdown, select the System Menu. The Viewer can also be restarted from here.
Acknowledgements
