Portsdown Band Viewer
The "Band Viewer" software is included with the Portsdown 4 and Portsdown 2020 and can be used to provide a basic spectrum display of band occupancy using the receive section of a LimeSDR, Pluto (Portsdown 4 only), Airspy R2 or RTL-SDR. It only works with the specified SDRs and the 7 inch screen (or the DSI-connected 5 inch screen), not the GPIO-connected 3.5 inch screen.
SDR | Frequency Coverage | Span Widths | Notes |
LimeSDR | 30 MHz - 3.5 GHz | 500 kHz, 1, 2, 5, 10, 20 MHz | LimeSDR Mini, LimeSDR USB or LimeNET Micro |
Pluto | 70 MHz - 6 GHz | 2, 5, 10, 20, 50 MHz | Portsdown 4 only |
Airspy R2 | 24 MHz - 1.7 GHz | 1, 2, 5, 10 MHz | Only Airspy R2 supported |
RTL-SDR | model-dependant | 1, 2 MHz |
Starting the Software
BandViewer can be selected from Portsdown Menu 2, BandViewer. The BandViewer for specific SDRs can also be selected from Menu 2, Test Equipment. On selection of the generic BandViewer button, the software checks for the presence of the SDRs in the order: Lime, Airspy, Pluto, RTL-SDR. It uses the first SDR that it finds, or displays an error message if it cannot find an SDR.
Frequency
The centre frequency can be directly entered from the keyboard (selected from the Settings menu) and a number of programmable presets are available. The centre frequency can be shifted down or up by 10% of the span width by using the left and right buttons on the main menu. The presets can be configured fronm the Mode, Set Config, Set Freq Presets Menu. Stored frequency and presets are specific to each SDR type.
From the Mode menu, ot is possible to reconfigure the display to show only 20dB of range. This is ideal for fine alignment of systems.
Measurements and Recording
Web Viewing
For this to work, "Web Control" needs to be enabled in th Portsdown software (Menu 2, System Config, Web Control Enable/Disable). Note that, unlike the Portsdown and Signal Generator software, web control of the Band Viewer is not possible - it is display only. Settings need to be adjusted using the touchscreen.
Resolution
Known Bugs and Limitations
Exit
Acknowledgements
