Portsdown Band Viewer
Revision as of 12:08, 23 November 2022 by G3gja (talk | contribs)
The "Band Viewer" software is included with the Portsdown 4 and Portsdown 2020 and can be used to provide a basic spectrum display of band occupancy using the receive section of a LimeSDR, Pluto (Portsdown 4 only), Airspy R2 or RTL-SDR. It only works with the specified SDRs and the 7 inch screen (or the DSI-connected 5 inch screen), not the GPIO-connected 3.5 inch screen.
SDR Characteristics
SDR Frequency Coverage Span Widths Notes
LimeSDR 30 MHz - 3.5 GHz 500 kHz, 1, 2, 5, 10, 20 MHz LimeSDR Mini, LimeSDR USB or LimeNET Micro
Pluto 70 MHz - 6 GHz 2, 5, 10, 20, 50 MHz Portsdown 4 only
Pluto 5th 6 GHz - 30 GHz 2, 5, 10, 20, 50 MHz Much Reduced Sensitivity
Airspy R2 24 MHz - 1.7 GHz 1, 2, 5, 10 MHz Only Airspy R2 supported
RTL-SDR model-dependent 1, 2 MHz
Starting the Software
BandViewer can be selected from Portsdown Menu 2, BandViewer. The BandViewer for specific SDRs can also be selected from Menu 2, Test Equipment. On selection of the generic BandViewer button, the software checks for the presence of the SDRs in the order: Airspy, LimeSDR, Pluto, RTL-SDR. It uses the first SDR that it finds, or displays an error message if it cannot find an SDR.
Frequency
Measurements and Recording
Web Viewing
For this to work, "Web Control" needs to be enabled in th Portsdown software (Menu 2, System Config, Web Control Enable/Disable). Note that, unlike the Portsdown and Signal Generator software, web control of the Band Viewer is not possible - it is display only. Settings need to be adjusted using the touchscreen.
Resolution
Known Bugs and Limitations
Exit
Acknowledgements
