Christmas 2022 Repeater Contest & Activity Challenge
Christmas 2022 BATC REPEATER ACTIVITY CONTEST and ACTIVITY CHALLENGE RULES
3. Dates and Times. The contest will run from 0000hrs GMT on 24th December 2022 to 2359hrs GMT on the 2nd January 2023.
6. Power. Output power must not exceed that set out in the terms of your licence. 7. Exchange. Both a CALL SIGN and a FOUR-FIGURE code number (not consecutive & four different digits) must be conveyed via video and received via the repeater by another station. Reception of the repeater can either be via the RF output or the repeater's streaming channel. The same exchange should be used for direct contacts for points to be valid in the Challenge.
Confirmation of reception is by transmitting back the sum of the code numbers (not the actual transmitted number) on the repeater or on the talk-back channel. Confirmation via the streaming chat channel or other non-radio means is allowed as is confirmation by another voice repeater (analogue or digital).
8. Scoring. The following multipliers should be used: 71MHz & 146MHz @ 5 points per km, 70cm @ 3 points per km, 23cm @ 2 points per km. Contacts on higher bands @ 5 points per km.
For the Christmas Repeater Activity Contest, you can claim points for repeating contacts on each day of the contest.
A single callsign can be worked via a repeater from up to two locations with unique QTH Locators, on the same day, band and with the same callsigns. For example, you can work into the repeater from home and then you can go out portable to another location and the points earned /P can be claimed for working the same stations on the same bands earlier in the day from the home station. You may not claim points for multiple contacts with the same station via the same repeater on the same day on different bands for any one unique location. RF or Internet links between two repeaters do not count for additional points.
For the Challenge, on any day you may work the same station on different bands and claim points for each contact from any location with a unique QTH Locator.
10. On-line logging. Use the Activity Ladder page on the BATC website here: https://batc.org.uk/ladder and fill in the boxes for each contact as appropriate.
11. Receive only section. Send an e-mail to the Contest Manager with log sheet attached giving your Call sign / BRS No. and name and address, Band, Date/Time, Call sign of station seen, Repeater Callsign, Repeater Locator, Locator of other station, Code number received, km from your station to repeater, km from repeater to distant station and points claimed.
Clive Reynolds G3GJA / G8EQZ BATC Contest Manager 30th November 2022
