UK ATV DX Records
This is a record of the UK DX records for each band. As well as the current record, it lists some previous records.
They are not complete and are based on trawling the forum activity pages and recent contest results - please update or let us know if you know better.
Note, these are UK records only (at least one of the stations involved was located in the UK) and only lists significant one way contacts.
World records are claimed based on the W6HHC list.
World DATV records
W6HHC
Ken W6HHC, maintains the record of the world DATV records here: https://w6ze.org/DATV/Known-DATV-DX-Records_2023.pdf <be>
Rob PE1CVJ and Rob MØDTS/p set a world record 1.2 GHz DATV record during the IARU ATV contest on June 10, 2023.
- 1.2 GHz record between the Netherlands and UK (465 KM) using a short opening of tropospheric reflections over the North Sea.
Rob PE1ITE traveled to a series of locations in France/Germany/Switzerland to conduct DATV QSOs during May 18-21 2023 on 146 MHz Two new world records were added in May 2023.
- 144 MHz record on May 20 2023 with PI6GN in the Netherlands (695 KM) using "airplane-scatter".
- another 144 MHz record on May 19 2023 with ON7MOR in Belgium (418 KM) using "airplane-scatter".
Please send Ken an e-mail if you know of a DATV QSO that should be added to this list! (via W6HHC@ARRL.net)
HB9AFO
HB9AFO also lists a record of mainly European records on all bands up to and including laser https://www.hb9afo.ch/records/default.htm
Historical records
CQ-TV 229 reports the following:
- The world’s first ATV QSO was performed between G3BLV/T and G5ZT/T in May 1952
- The first colour ATV QSO was performed over 12 miles from Great Baddow to Dunmow Essex in December 1956
- An ATV QSO over 200 miles was completed between G3ILD and G3NOX/T end of 1963
If you have any more details on these QSOs or other early records please contact any member of the committee.
50MHz
Date | Distance | Station 1 | Location | Station 2 | Location | Mode | Comments |
10-12-2014 | 4.5 kms | M0SKM | IO91RV | G4CPE | IO91SW | 543Ks | |
08-11-2018 | 7.5 kms | G8GTZ/P | IO91KD - Wield | G8LES | IO91LC | 333Ks | Forum report |
26-12-2018 | 228 kms | G4FRE | IO82UC - Malvern | G0FRE/P | JO01JK - Isle of Sheppey | 250Ks | One way only [1] |
06-04-2019 | 140 kms | G4FRE/P | IO82QJ - Titterstone Clee | G8GTZ/P | IO91GI - Walbury | 250Ks | World record?? |
71MHz
UK only
25-07-2018 | 59 kms | G8VPG/P | IO81LS - Blorenge | G4BVK/P | IO81TK - Togg Hill | 333Ks | Forum report |
14-09-2018 | 136 kms | G8VPG/P | IO81FE - Dunkery Beacon | G8BVK/P | IO81XW - Cleeve common | 333Ks | Forum report |
09-12-2018 | 160 Kms | G8GTZ/P | IO80WX - Win Green | G4FRE/P | IO82QJ - Titterstone Clee | 125Ks | Forum Report |
27-12-2018 | 230 kms | G4FRE | IO82UC - Malvern | G0FRE/P | JO01KK - Isle of Sheppey | 250Ks | One way only [2] |
146MHz
UK only band released for amateur use on October 10th 2014
30-12-2014 | 3.6 kms | G4CPE | IO91SW | G0WFT | 333Ks | First One way | |
11-01-2015 | 28 kms | G0LPS | IO94EQ | M0DTS | 333Ks | First 2 way QSO | |
21-02-2015 | 50 kms | G0LPS | IO94EQ | M0DTS/P | 333Ks | ||
13-06-2015 | 95 kms | G8GTZ/P | IO91GI - Walbury Hill | G4CPE | IO91SW | 333Ks | |
13-06-2015 | 115 kms | G0LPS | IO94EQ | M0DTS/P | 333Ks | ||
11-06-2016 | 121 kms | G8VPG/P | IO81LS - Blorenge | G8GKQ/P | IO91GI - Walbury | 333Ks | Report |
03-09-2016 | 169 kms | G8VPG/P | IO80WX - Win Green | G8GTZ/P | IO82QL - Brown Clee | 333Ks | Report |
03-09-2016 | 182 kms | G8GTZ/P | IO82QL - Brown Clee | G8GKQ/P | IO80UU - Bulbarrow | 333Ks | Report |
11-12-2016 | 185 kms | G8GTZ/P | IO90JO - Ventnor | G8VPG/P | IO81LS - Boringe | 333Ks | Report |
29-12-2016 | 277 kms | G8GTZ | IO91KF | G0MJW | IO83RO | 333Ks | Report |
30-12-2016 | 294 kms | G8LES | IO91LC | G0MJW | IO83RO | 333Ks | |
14-07-2018 | 313 kms | GI7UGV/P | IO74AU | G4CBW | IO83UB | 333Ks | Report |
24-10-2018 | 407 kms | M0DTS/P | IO94MJ | G4UVZ | IO80KX | 333Ks | World Record Report |
70cms
10-04- 1991 | 295 kms | G8EQZ/P | IO93PV79 | G8MNY/P | South Downs | ATV | CQ-TV 151 |
Sept 1991 | 346 kms | GW7ATG/P | G1COI/P | ATV | IARU 1991 CQ-TV 158 | ||
24/9/2013 | 528 Kms | G3PYB/P | F6AQO | ||||
24-09- 2013 | 696 kms | G8GTZ | IO91KH | F1FY | JN16VB | DATV | 2 way QSO over 24 hour period! World record |
23cms
June 1991 | 319 kms | G7ATV/P | Mendips | G8EQZ/P | IO93PV79 | ATV | Summer fun 1991 CQ-TV 156 |
September 2003 | 327 kms | G7ATV/P | IO91QG | G4YTV | IO93UU82 | ATV | IARU 2003 |
October 2010 | 440 kms | G4KLB | Bournemouth | M0DTS | Yarm | DATV | World Record |
13cms
Sept 2003 | 263km | G6COL/P | IO93RG | G7ATV/P | IO81QC | ATV | IARU 2003 |
9 June 2018 | 85 km | G8GTZ/P | IO90LX Wether Down | G8GKQ/P | IO80WP Lulworth | 1 MS DATV | |
9 June 2019 | 92 km | G8GTZ/P | IO81FD Dunkery Beacon | G8GKQ/P | IO80UV Okeford Hill | DATV | |
12-06-2021 | 136.8 kms | G8GTZ/P | IO81FD Dunkery Beacon | G4FRE/P | IO81XW- Cleeve Common | 333Ks DATV |
9cms (3.4GHz)
09-06-2017 | 51 kms | G1LPS | IO94EQ | M0DTS/P | IO94DF - Masham | DATV | |
17-11-2019 | 73 kms | G8GTZ/P | IO91GI Walbury | G4FRE/P | IO81XW Cleeve Common | DATV | |
12-06-2021 | 136.8 kms | G8GTZ/P | IO91GI Walbury | G4FRE/P | IO81XW Cleeve Common | DATV | 333Ks DATV |
10-06-2018 | 154 kms | GW4CBW/P | IO83FD - Bylchau | G3NWR/P | IO84ML - Kirkstone | DATV |
6cms (5.6GHz)
09-06-2017 | 80 kms | G8GTZ/P | IO80WP - Povingdon Hill | G8GKQ/P | IO90LU - Portsdown Hill | ATV | |
July 2017 | 88 kms | G8GTZ/P | IO90LX - Wether Down | G8GKQ/P | IO80WP - Povingdon Hill | ATV | |
12-06-2021 | 138 kms | G8GTZ/P | IO81FD - Dunkery Beacon | G4FRE/P | IO81XW - Cleeve common | DATV | 333kS |
29-08-2017 | 138 kms | G8GTZ/P | IO81FE - Dunkery Beacon | G8GKQ/P | IO81XW - Cleeve common | ATV | Report |
April 2018 | 153 kms | GW3NWR/P | IO83FD - Bylchau | M0KPW/G0HIK/P | IO84ML - Kirkstone | ATV | |
09-05-2018 | 158 kms | G4NJJ/P | JO02OW - East Runton | G8AGN / G0RPH/P | IO94VB - Bridlington | ATV | Report |
29-06-2018 | 159 kms | GI7UGV/P | IO74DN - Scrabo | G0HIK / M0KPW/P | IO84IH - Corney | ATV | Report |
05-07-2018 | 180 kms | GI0GDP/P | IO74AU - Larne | G0HIK / M0KPW/P | IO84IH - Corney | ATV | Report |
25-10-2018 | 190 kms | G8GTZ/P | IO81XW - Cleeve Common | G3NWR/P | IO83RO- Winter Hill | ATV | Report |
25-10-2018 | 370 kms | G8VPG/P | IO81QF - Mendips | M0DTS/P | IO94MJ - NY Moors | ATV | Report |
World record = 464km JA0DAE > JA0RUZ
3cms (10GHz)
Sept 2003 | 76kms | G7ATV/P | IO81QG - Mendips | GW0NOS/P | IO81FP | ATV | IARU 2003 |
Spring 2007 | 50kms | G3PYB/P | Hoggs Back | G8ADM | Stanmore | DATV one way | Scatterpoint March 2007 |
03-07-2016 | 93 kms | G8GTZ/P | IO91GI - Walbury | G8GKQ/P | IO80WP - Povingdon | 333 Ks | |
27-08-2017 | 136 kms | G8GTZ/P | IO81FE - Dunkery Beacon | G8GKQ/P | IO81XW - Cleeve Common | 333 Ks | Forum |
25-10-2018 | 407 kms | M0DTS/P | IO94MJ - NY Moors | G4UVZ | IO80KX | 2Ms DATV | Forum report |
World record = 904.12 km IT5HZM - IW9GUR
24GHz
11-06-2017 | 51 kms | G1LPS | IO94EQ | M0DTS/P | IO94DF - Masham | DATV | |
10-06-2018 | 85 kms | G8GTZ/P | IO90LX - Wether Down | G8GKQ/P | IO80WP - Povingdon Hill | DATV | |
14-05-2019 | 126.6 kms | G4FRE/P | IO82QL - Brown Clee | G4CBW/P | IO83SO - Winter Hill | 1Ms DATV | |
14-05-2019 | 126.6 kms | G8GTZ/P | IO82QL - Brown Clee | G4CBW/P | IO83SO - Winter Hill | 1Ms DATV | - Report |
09-06-2019 | 136.8 kms | G8GTZ/P | IO81FD - Dunkery Beacon | G4FRE/P | IO81XW81 - Cleeve Common | 333Ks DATV |
World record = 186 km IW9ARO in Sicily to 9H1GB in Malta. April 2023 http://www.hb9afo.ch/records/default.htm#24_GHz
47GHz
24-08-2019 | 34.9 km | G4FRE | IO82UC05 - Malvern | G0FRE/P | IO92BA - Broadway | DATV 1 Ms/s | |
14-10-2020 | 51.9 km | G4FRE/P | IO91GI61 - Coombe Mast | G4LDR/P | IO90MX13 - Butser | DATV 333 ks/s | |
25-06-2021 | 66 km | G4FRE/P | IO91BV - Notgrove | G8GTZ/P | IO91GI - Walbury | One way only - DATV 333 ks/s | |
26-09-2021 | 67 km | GW4FRE/P | IO81LS19 - Blorenge | G8GTZ/P | IO81WU71 - Birdlip Hill | DATV 125ks/s | |
26-09-2021 | 74 km | GW4FRE/P | IO81LS19 - Blorenge | G8GTZ/P | IO81XW81 - Cleeve Common | DATV 125ks/s |
World record = 115km JA0RGP in PM97MT > JA0RUZ in PM96FV
76GHz
09-06-2018 | 12 kms | G8GTZ/P | IO90LX - Wether Down | G4LDR/P | IO90LU - Portsdown Hill | 250Ks RB-TV | |
13-01-2019 | 28 kms | G8GTZ/P | IO91JH - Hannington | G4LDR/P | IO91JB - Cheesefoot Head | 2Ms HD! | |
28-01-2019 | 35.6 kms | G8GTZ/P | IO91GI61 - Combe Mast | G4LDR/P | IO91JB - Cheesefoot Head | 333Ks | World record |
122GHz
11-06-2022 | 5.6 km | G4FRE/P | IO93OX - Garrowby | G4NXO/P | IO93PW - Millington | DATV 250 ks/s | IARU 2022 World Record |
134GHz
Example |
