Portsdown - where do I begin?
Once you've read the Hardware overview, you can see there's not much to it! So here's the shopping list...
Shopping list
Raspberry Pi
Ideally you will buy a version 3, but if you have a version 2 or even a Model B lying in the cupboard, give it a try. Because, believe it or not, that's all you need to send pictures across the shack! But to do this you will have to read another section of the user manual and follow some instructions!
So go and have a look at the initial set up guide - follow those instructions and using QPSKRF Ugly mode, you will be able to send pictures across the shack but you really need to read this section on Ugly mode as there's several things it cannot do.
However, if you do not want to always have a computer connected, you'll need to buy the touchscreen.
Longwave....
The Raspberry camera
An Easycap USB dongle
This has a yellow video phono connector on it and will enable you to connect you mixing desk, old camcorder or even your old VHS tape machine!
Modulator Filter PCB
Right now, that's all you can do because the modulator / filter board is not quite ready. Once it is (and you'll be able to buy it from the BATC shop) this will enable you to get on air properly with DATV on 146, 437 and 23cms.
ADF4351 Local Oscillator
As well as the Modulator Filter board you will need an ADF4351 chip to use as your local oscillator - luckily, these are available from ebay ready assembled on a smal PCB with an SMA connector so is simply "plug and play". These are available now and the Portsdown transmitter will definitely use one, so you can buy one now so you are ready when the Modulator board is available.
Filters and drivers
That's all there is to the Portsdown transmitter - 4 simple sets of parts, but of course, just like any other DATV transmitter, you will need filters and driver amplifiers - there's lot of designs around and anything you have built or bought for Digilite or DTX1 will work well with the Portsdwon transmitter.
