Portsdown Band Viewer
The "Band Viewer" software is included with the Portsdown 4 and Portsdown 2020 and can be used to provide a basic spectrum display of band occupancy using the receive section of a LimeSDR, Pluto (Portsdown 4 only), SDRPlay RSPdx (Portsdown 4 only), Airspy R2 or RTL-SDR. It only works effectively with the specified SDRs and the 7 inch screen (or the DSI-connected 5 inch screen). It has a limited capability with the Waveshare 3.5 inch screen on the Portsdown 2020, but only with the RTL-SDR. See here for details.
Note - references to the SDRPlay RSPdx are in advance of the capability being released. It is only available for beta testers at present
| SDR | Frequency Coverage | Span Widths | Notes |
| LimeSDR | 30 MHz - 3.5 GHz | 500 kHz, 1, 2, 5, 10, 20 MHz | LimeSDR Mini, LimeSDR USB or LimeNET Micro |
| Pluto | 70 MHz - 6 GHz | 2, 5, 10, 20, 50 MHz | Portsdown 4 only |
| Pluto 5th | 6 GHz - 30 GHz | 2, 5, 10, 20, 50 MHz | Much Reduced Sensitivity |
| RSPdx | 1 kHz - 2 GHz | 100, 200, 500 kHz, 1, 2, 5, 10 MHz | Portsdown 4 only |
| Airspy R2 | 24 MHz - 1.7 GHz | 1, 2, 5, 10 MHz | Only Airspy R2 supported |
| RTL-SDR | model-dependent | 500 kHz, 1, 2 MHz |
Pluto Set-up
Starting the Software
BandViewer can be selected from Portsdown Menu 2, BandViewer. The BandViewer for specific SDRs can also be selected from Menu 2, Test Equipment. On selection of the generic BandViewer button, the software checks for the presence of the SDRs in the order: Airspy, SDRplay, LimeSDR, Pluto, RTL-SDR. It uses the first SDR that it finds, or displays an error message if it cannot find an SDR. If a connected SDRplay is not detected, it may be necessary to specifically select the SDRplay from the Test Equipment menu to load the driver.
Frequency
Measurements and Recording
Web Viewing
For this to work, "Web Control" needs to be enabled in th Portsdown software (Menu 2, System Config, Web Control Enable/Disable). Note that, unlike the Portsdown and Signal Generator software, web control of the Band Viewer is not possible - it is display only. Settings need to be adjusted using the touchscreen. Exceptionally, web control is available on the SDRPplay BandViewer - see below.
Resolution
Known Bugs and Limitations
SDRplay RSPdx Capability - Portsdown 4 Only
The SDRplay RSPdx is a complex SDR with good performance. It needs special drivers, which sometimes take a while (up to 90 seconds) to be loaded when selected. It should be connected to one of the (black) USB2 ports on the Raspberry Pi 4. The ((blue) USB3 ports do not work for the SDRplay.
There are gain settings for both the IF Gain and the RF Gain. A good starting point for BandViewer is an RF Gain of 0 dB, and an IF gain of -10 dB. The AGC facility does work, but is not recommended with BandViewer.
On the "Waterfall Config" menu (more about the waterfall below), the desired Antenna input for the RSPdx can be selected. Enter 0 for input A, 1, for input B and 2 for imput C. The 4.7v Bias T LNA supply on input B can also be switched on an off from this menu.
Although the SDRplay RSPdx BandViewer might work with other SDRs from the SDRplay family (such as the RSP 1a or RSP 2), it has not been tested with them. The gain settings may not be optimum, and the input and LNA switching is unlikely to work.
Unlike other versions of BandViewer, the "Set Frequency Presets" menu is accessed from the "System" menu.
Web view is available for the SDRplay BandViewer, and also web control. Note that web view only updates the screen once per second so spectrums and waterfalls will appear to be jerky.
Waterfall Capability
The SDRplay BandViewer includes a waterfall capability. This is selected from the Mode Menu. There are 2 waterfall modes: mix mode, where the top quarter of the screen displays a spectrum and the lower three quarters displays a waterfall, and Waterfall mode, where the waterfall fills the screen.
The waterfall is configured from the "Waterfall Config" menu. "Set Waterfall Base Level" sets the signal strength below which the waterfall will paint black. "Set Waterfall Range" adds to the base level to set the signal strength above which the waterfall will paint white. These settings should be adjusted so the the base level is just below the noise floor, and the range includes the strongest signals. Selecting "Mode" and "Classic SA Display" will show a small strip of the waterfall spectrum to the right of the normal bandviewer display to enable these levels to be set properly. Good starting values for these are a base level of -70 and a range of 60. For clearer display of weaker signals, the range should be reduced.
The other waterfall setting is the Waterfall Time Span. This sets the time taken for any event to move from the top of the screen to the bottom of the screen (in seconds). A good starting setting is 10 seconds. The waterfall moving speed is the same in Mix mode, so the time from top to bottom is reduced by 25% as the available screen is shorter. The minimum time is about 3 seconds - this is limited by computing speed.
At slow waterfall speeds, the peak level of all events that occur between the writing of each new line on the waterfall is displayed. This is why the background brightness appears to increase at low waterfall speeds, because more noise peaks are being captured.
It is hoped to add the waterfall capability to the BandViewer for other SDRs when time permits.
The BandViewer software was written to only support the 7 inch screen with an 800x480 picture size. The Waveshare 3.5 inch screen has a framebuffer size of 720x576, so there is no room for the control buttons on the right hand side. However, the RTL-SDR BandViewer can be run in fixed-frequency, fixed span width and fixed gain mode by using the following procedure:
- Connect an RTL-SDR and start Portsdown
- Select RX. If you have no MiniTiouner connected, touch the screen to continue - it does not matter.
- On the receiver menu, Make sure that you have "Terrestrial", not "QO-100" selected in the top left button. Touch the button to change it if required.
- Select the centre frequency that you want to tune BandViewer to. If it is not on one of the presets, select the button labelled keyboard and you can enter the frequency.
- Select the bottom right button "BandViewer on RX Freq". If the button is grey, not blue, it means that you do not have an RTL-SDR connected.
- After a pause, BandViewer should start on your selected centre frequency, with a 2 MHz span width.
- You cannot adjust the settings.
- To return to Portsdown (and possibly select a new centre frequency) simply touch the screen.
- Having set the correct centre fequency, the BandViewer can be reselected directly from Portsdown Menu 2.
Exit
Acknowledgements
