Portsdown Band Viewer
The "Band Viewer" software is included with the Portsdown 4 and Portsdown 2020 and can be used to provide a basic spectrum display of band occupancy using the receive section of a LimeSDR, Pluto (Portsdown 4 only), SDRPlay RSPdx (Portsdown 4 only), Airspy R2 or RTL-SDR. It only works effectively with the specified SDRs and the 7 inch screen (or the DSI-connected 5 inch screen). It has a limited capability with the Waveshare 3.5 inch screen on the Portsdown 2020, but only with the RTL-SDR. See here for details.
SDR | Frequency Coverage | Span Widths | Notes |
LimeSDR | 30 MHz - 3.5 GHz | 100, 200, 500 kHz, 1, 2, 5, 10, 20 MHz | LimeSDR Mini, LimeSDR USB or LimeNET Micro |
Pluto | 70 MHz - 6 GHz | 2, 5, 10, 20, 50 MHz | Portsdown 4 only |
Pluto 5th | 6 GHz - 30 GHz | 2, 5, 10, 20, 50 MHz | Much Reduced Sensitivity |
RSPdx | 1 kHz - 2 GHz | 100, 200, 500 kHz, 1, 2, 5, 10 MHz | Portsdown 4 only |
Airspy R2 | 24 MHz - 1.7 GHz | 1, 2, 5, 10 MHz | Only Airspy R2 supported |
RTL-SDR | model-dependent | 500 kHz, 1, 2 MHz |
Pluto Set-up
Starting the Software
BandViewer can be selected from Portsdown Menu 2, BandViewer. The BandViewer for specific SDRs can also be selected from Menu 2, Test Equipment. On selection of the generic BandViewer button, the software checks for the presence of the SDRs in the order: Airspy, SDRplay, LimeSDR, Pluto, RTL-SDR. It uses the first SDR that it finds, or displays an error message if it cannot find an SDR. If a connected SDRplay is not detected, it may be necessary to specifically select the SDRplay from the Test Equipment menu to load the driver.
Frequency
When using the SDRplay and LimeSDRs, the 0 dB line is calibrated to 0 dBFS. This corresponds to the maximum signal stength that a single carrier can be displayed at with no distortion. At lower span widths, this can take the noise level below -80 dB. There is a setting on the Mode Menu (LimeSDR) or Gain Menu (SDRplay) to "Show 20dB lower". This shifts the whole display so that levels down to -100 dB are visible.
Measurements and Recording
Web Viewing
For this to work, "Web Control" needs to be enabled in the Portsdown software (Menu 2, System Config, Web Control Enable/Disable). Note that, unlike the Portsdown and Signal Generator software, web control of the Band Viewer is not possible - it is display only. Settings need to be adjusted using the touchscreen. Exceptionally, web control is available on the SDRplay BandViewer - see below.
Resolution
Known Bugs and Limitations
LimeSDR BandViewer shows a DC noise spike of between 15 and 20 dB amplitude in the centre of the display. This is hidden if a reasonable gain preamp is used in front of the LimeSDR.
SDRplay RSP Capability - Portsdown 4 Only
The SDRplay RSP family are complex SDRs with good performance. They need special drivers, which sometimes take a while (up to 90 seconds) to be loaded when selected. They should be connected to one of the (black) USB2 ports on the Raspberry Pi 4. The (blue) USB3 ports do not always work for the SDRplay. The BandViewer has been tested with the RSPdx and RSP2pro; other RSP series SDRs should work, but have not been tested.
There are gain settings for both the IF Gain and the RF Gain. A good starting point for BandViewer is an RF Gain of 0 dB, and an IF gain of -10 dB. The gain setting calibration is only valid for the RSPdx. The AGC facility does work, but is not recommended with BandViewer. The top of the screen is set to be "digital full scale" (also known as 0 dBFS). This can sometimes push the noise floor off the bottom of the screen; it can be brought back into into view by selecting "Show 20dB Lower" on the gain menu. Note that the IF Gain and RF gain calibration settings are only valid for the RSPdx. They do change the gain on other models, but not by the factor indicated on the button.
On the "Advanced Config" menu (accessed through "Settings", "Waterfall Config", "Advanced Config"), the desired Antenna input for the RSPdx can be selected. Enter A, B or C; for the Hi-Z input, select C. The 4.7v Bias T LNA supply on the supported input can also be switched on an off from this menu. A frequency offset can also be set that changes the frequency calibration on the display. For a receiver with a low side LO, simply enter the the LO frequency in Hz (such as 9750000000 for a standard QO-100 LNB). For a receiver with a high side LO, enter the LO frequency as negative (such as -5150000000 for a C-Band LNB); with a high side LO, the spectrum is also reversed so that it looks correct. In all cases, the frequency entry for the centre frequency needs to at the actual SDR centre frequency (such as 745 MHz for a standard QO-100 LNB). Any reported marker frequency is likely to be at the SDR frequency, and possibly incorrect for high-side mixing.
RSP Clones are reported to work with BandViower, but have much poorer performance than the genuine article; at least 20 dB less sensitive with lots of additional spurii.
Unlike other versions of BandViewer, the "Set Frequency Presets" menu is accessed from the "System" menu.
Web view is available for the SDRplay BandViewer, and also web control. Note that web view only updates the screen once per second so spectrums and waterfalls will appear to be jerky.
Waterfall Capability
The SDRplay and LimeSDR BandViewers includes a waterfall capability. This is selected from the Mode Menu. There are 2 waterfall presentation modes: "Mix" mode where the top quarter of the screen displays a spectrum and the lower three quarters displays a waterfall, and "Waterfall" mode where the waterfall fills the screen.
The waterfall is configured from the "Waterfall Config" menu. "Set Waterfall Base Level" sets the signal strength below which the waterfall will paint black. "Set Waterfall Range" adds to the base level to set the signal strength above which the waterfall will paint white. These settings should be adjusted so the the base level is just below the noise floor, and the range includes the strongest signals. Selecting "Mode" and "Classic SA Display" will show a small strip of the waterfall spectrum to the right of the normal bandviewer display to enable these levels to be set properly. A smaller version of this strip is also displayed in "Mix" mode. Good starting values for the settings are a base level of -70 and a range of 60. For clearer display of weaker signals, the range should be reduced.
The other waterfall setting is the Waterfall Time Span. This sets the time taken for any event to move from the top of the screen to the bottom of the screen (in seconds). A good starting setting is 10 seconds. The minimum time is about 3 seconds - this is limited by computing speed and varies with processor load; for this reason the time calibration scale is not displayed when Time Spans of less than 5 seconds are selected.
The waterfall has 3 amplitude display modes selected from the Waterfall Config Menu:
- "Waterfall Normal" displays a single fft sample for each displayed waterfall line and discards the ones that occur in between the waterfall lines. This means that some short-duration RF events might be missed as they occur in the interval between waterfall lines.
- "Waterfall Average" takes the arithmetic mean of the each fft sample that is taken between the time for display of waterfall lines.
- "Waterfall Peak" uses the highest power value that occurs on each frequency for all fft samples between the display of waterfall lines.
Waterfall peak is best for detecting short-duration RF events, but the background noise level varies with the uneven rate of waterfall sampling. This variation is due to the processor being busy with other tasks. Waterfall Normal is best for detecting an amatur signal during fading conditions. Waterfall Average is a compromise between these 2 solutions.
It is hoped to add the waterfall capability to the BandViewer for the Pluto and RTL-SDR when time permits.
The BandViewer software was written to only support the 7 inch screen with an 800x480 picture size. The Waveshare 3.5 inch screen has a framebuffer size of 720x576, so there is no room for the control buttons on the right hand side. However, the RTL-SDR BandViewer can be run in fixed-frequency, fixed span width and fixed gain mode by using the following procedure:
- Connect an RTL-SDR and start Portsdown
- Select RX. If you have no MiniTiouner connected, touch the screen to continue - it does not matter.
- On the receiver menu, Make sure that you have "Terrestrial", not "QO-100" selected in the top left button. Touch the button to change it if required.
- Select the centre frequency that you want to tune BandViewer to. If it is not on one of the presets, select the button labelled keyboard and you can enter the frequency.
- Select the bottom right button "BandViewer on RX Freq". If the button is grey, not blue, it means that you do not have an RTL-SDR connected.
- After a pause, BandViewer should start on your selected centre frequency, with a 2 MHz span width.
- You cannot adjust the settings.
- To return to Portsdown (and possibly select a new centre frequency) simply touch the screen.
- Having set the correct centre fequency, the BandViewer can be reselected directly from Portsdown Menu 2.
Exit
Acknowledgements
