PicoTuner
A USB tuner for DATV using the RpiPico as the USB interface
Whilst the PicoTuner was designed for use in a new tuner design it can also be retrofitted to the BATC V2 Minitiouner and similar designs providing their FTDI modules are fitted in sockets. This involves removing the FTDI module, replacing it with an adaptor pcb and adding 5 wires to connect signals that are not present on the FTDI sockets. The advantage of doing this upgrade is to provide access to the second TS. When supported by the host software this then allows the reception of two signals at the same time. To save space and to try to make the module mechanically compatible surface mount techniques are used. However due to the large size of the components involved it is still easily assembled by hand.
PCB :- These will be available from the BATC shop, or you can get your own made using one of the Chinese PCB manufacturers. The Gerber files are available here https://github.com/g4eml/PicoTuner/tree/main/Adaptor
Raspberry Pi Pico :- Surface mount version without pin headers.
The Pi Hut Part Number:- SC0915 Mouser Part Number :- 358-SC0915
Harwin Part Number:- M20-8761346 Mouser Part Number:- 855-M20-8761346 Farnell Part Number :- 3756209
Harwin Part Number:- M20-9990545 Mouser Part Number:- 855-M20-9990545 Farnell Part Number :- 1022252
Assembly Instructions
Connect J1 Pin 1 to D7
Connect J1 pin 2 to CLK
Connect J1 pin 3 to VA
Programming the Pico
This can be done either before or after the Pico has been fitted to the Minitiouner, it makes no difference. Updating to a new firmware version is done the same way.
