HAMTV from the ISS
The original HamTV unit was installed on the ISS in 2013 and commissioned in April 2014 and was used for a number of ARISS schools contacts in 2016 - 2018. The unit failed in 2019, but is now expected to be returned to the ISS on the SpaceX SpX-30 flight currently scheduled for March 12th 2024
It is hoped that it will be recommissioned by a visiting astronaut during within a few weeks of its arrival.
HAMTV specifications
- 2369 MHz
- 2422 MHz
- 2437 MHz
DVB-S modulation
- Symbol rates: 1.3 Ms/s or 2.0 Ms/s
- FEC : ½
RF output
HAMTV antenna
This patch antenna is located on the earth facing side of the ISS but is surrounded by solar panels, thermal radiator panels, two or more visiting vehicles and robotic arms.
Video format
- NTSC
- SIF resolution: 352×240 or D1:720×480
What is HAMTV used for?
During the first flight on the ISS between 2014 and 2018 it was used primarily for ARISS schools contacts but transmitter was left on at other times but no video was transmitted. This did allow ground stations to test their receive equipment and it is hoped a test signal generator will be included when it is re commissioned in 2024.
Once re-commissioned it will be tested before contacts and will be added to the AMSAT status page https://www.amsat.org/status/
How to receive HAMTV?
The HamTV transmission runs relatively low power on 2395MHz to a simple patch antenna on the ISS. This patch antenna is located on the earth facing side of the ISS but is surrounded by solar panels, thermal radiator panels, two or more visiting vehicles and robotic arms. The ISS also “flies” slightly nose down to protect the cupola windows from space debris and so the RF performance, particularly when it is rising from the west, is slightly unpredictable.
Suitable feeds
Pre-amp and filter
A low noise pre-amp with bandpass filter tuned to 2395MHz should be connected directly to the antenna feed point to minimise co-ax losses.
Note that 2395MHz is only 5MHz below the 2.4GHz WiFi Channel 1, so good filtering will be needed to prevent strong, local WiFi signals from getting into the wide band satellite tuner and causing interference or desense.
If you are using a downconverter, a bandpass filter at the IF frequency in L band is possible.
Do I need a downconverter
Digital receivers for HAMTV
A receiver, such as a typical consumer STB, that need to scan the frequency is unlikely to lock to the signal in the time available during the pass. This solution is therefore not recommended.
Receivers designed for DATV
When the original HAMTV was on the air, due to a problem with the DVB tables in the transmission, the MiniTiouner software by F6DZP running on Windows had to be used.
During the last 8 years many developments have taken and so we have a choice of software:
- Ryde - Raspberry Pi 4 based set-top box software designed specifically for DATV
- Portsdown -
- Opentuner
Finding the signal
Tracking the ISS
Computer software is required to control the rotator system – there are a number of programs out there but I prefer PSTrotator which is a very versatile system with almost unlimited number of interfaces to control rotators.
Testing your system
Measuring sun noise
Portsdown DATV test system
The Portsdown DATV transceiver and test system has a continuous noise measurement facility designed to measure sun noise and is very simple to use. Simply connect the signal from your LNA to the rx port on a Pluto or Lime SDR and run the software - see https://wiki.batc.org.uk/Portsdown_Noise_Meter
SDR continuum mode
Decoding a local signal
Receiving HamTV
https://forum.batc.org.uk/posting.php?f=2&mode=post&sid=9c1b12a07706567454ebeca685548796
BATC TS merger system
