HAMTV from the ISS
The unit failed in 2019, and was returned to earth for repair. It is expected to be returned to the ISS on the SpaceX SpX-30 flight currently scheduled for March 12th 2024. It is hoped that it will be recommissioned by a visiting astronaut within a few weeks of its arrival.
HAMTV specifications
- 2369 MHz
- 2422 MHz
- 2437 MHz
DVB-S modulation
- Symbol rates: 1.3 Ms/s or 2.0 Ms/s
- FEC : ½
RF output
HAMTV antenna
This patch antenna is located on the earth facing side of the ISS but there are many other items that project below the antenna and may cause reflections. These include the solar panels, thermal radiator panels, sometimes, two or more visiting vehicles and robotic arms. Depending upon your location in respect to the ISS, these projections may result in strong reflected signals as well as the one from the patch antenna itself. They may cause disturbances to the signal level you receive
Video format
- MPEG-2, approx. 800kbps
- NTSC
What is HAMTV used for?
During the first flight on the ISS between 2014 and 2018 it was used primarily for ARISS schools contacts but transmitter was left on at other times but no video was transmitted. This did allow ground stations to test their receive equipment and it is hoped a test signal generator will be included when it is re commissioned in 2024.
Once re-commissioned it will be tested before contacts and will be added to the AMSAT status page https://www.amsat.org/status/
How to receive HAMTV?
A 1 meter or larger dish is optimum but smaller antennas such as flat plate or patch antennas will work and have the advantage of a wider beamwidth making it easier to track the ISS. They are unlikely to work at low elevations.
Suitable feeds
Pre-amp and filter
ADD IMAGE(S) OF PREAMPS HERE
A low noise pre-amp with bandpass filter tuned to 2395MHz should be connected directly to the antenna feed point to minimise co-ax losses.
Note that 2395MHz is only 5MHz below the 2.4GHz WiFi Channel 1, so good filtering will be needed to prevent strong, local WiFi signals from getting into the wide band satellite tuner and causing interference or desense.
If you are using a downconverter, a bandpass filter at the IF frequency in L band is possible.
Do I need a downconverter?
Note: place image of Minitiouner here
Digital receivers for HAMTV
A receiver, such as a typical consumer STB, that need to scan the frequency is unlikely to lock to the signal in the time available during the pass. This solution is therefore not recommended.
Receivers designed for DATV
During the last 8 years many developments have taken and so we expect now to have a choice of software:
- Ryde - Raspberry Pi 4 based set-top box software designed specifically for DATV
- Portsdown -
- Opentuner
Finding the signal
Tracking the ISS
Testing your system
Measuring sun noise
Portsdown DATV test system
The Portsdown DATV transceiver incorporates a test function that has a continuous noise measurement facility designed to measure sun noise. It is very easy to use. Simply connect the signal from your LNA to the rx port on a Pluto or Lime SDR and run the software - see https://wiki.batc.org.uk/Portsdown_Noise_Meter
SDR continuum mode
Decoding a local signal
Receiving HamTV
https://forum.batc.org.uk/posting.php?f=2&mode=post&sid=9c1b12a07706567454ebeca685548796 (NOT SURE THIS LINK IS CORRECT!)
