Portsdown transmitter FAQ
- How do I turn the transmitter off in Touchscreen mode?
- What do I need to receive a Portsdown transmitter?
As the Portsdown transmitter when fitted with the filter / modulator card will run normal bandwidth modes you will be able receive it on any Free to Air (or FreeSat) Set top box - High Definition STBs will decode MPEG-2 and MPEG-4.
However, when it is running in RB-TV modes OR in Ugly mode without the Filter Modulator card you can only receive it using Minituner - the PC based hardware and software receiver see here for more details.
- What is the Portsdown receiver?
The Portsdown receiver will be a development of the Minitune receiver with a simple user interface and new hardware giving continuous coverage from 140 to 2650 MHz meaning we no longer need receive upconverters to cover 146 and 437 MHz.
- Can I use another touchscreen LCD?
Maybe! The Portsdown project only supports the Waveshare screen - that doesn't mean to say others won't work but we can't help you if it doesn't.
- Who are the Portsdown team?
The Portsdown team are just BATC members doing this as volunteers to support the ATV community. As such, it is not their full time job and they are not being paid. If you have a problem, question or comment, please do not contact them directly but use the BATC members forum but there may not always be an instant response! And yes we are looking for people to help with the project - if you can write Linux, update Wiki pages or reply to forum posts we want to hear from you!
- Do I need to know about Linux or other clever computer stuff to get Portsdown running?
- Does Portsdown mean BATC will stop selling the DTX1 like they did DATVexpress?
NO - The DTX1 is designed for those who do not want to "build their own" and will still be available in the BATC shop and supported by Antennair through the DTX1 support website. DATVexpress is still available from the DATVexpress website - the reason we stopped selling is in the BATC shop is because the Express team wanted to offer it directly to end users.
- Is Portsdown MPEG-2 or MPEG-4?
Both - The Rpi hardware encoder runs MPEG-4 and the Portsdown software has an MPEG-2 encoder both of which are used in the Portsdown transmitter.
- Why doesn't MPEG2 mode work?
MPEG2 mode currently does not work if you have an analog capture device connected (it upsets the numbering of video devices). If you want MPEG2 mode, unplug the analog capture USB and reboot - it should work. It is hoped to overcome this issue with a software change shortly.
