PicoTuner Hardware
Mike G0MJW is designing a PCB which will host the Serit NIM and Pico board - it will look something like this:
Draft schematic is available here Media:PicoTuner-V2AR.pdf
Draft BOM is available here: File:PicoTunerADJBOM.xlsx
Programming the Pico
