PicoTuner Hardware
Mike G0MJW has designed a PCB which will host the Serit NIM and Pico board.
The schematic is available here File:PicoTunerFinal.pdf
Draft BOM is available here: File:PicoTunerADJBOM.xlsx
Construction if straight forwards, best done according to the height of the component being fitted. The LNB supply chip is the most challenging as it is an SMD device and has a pad on the base that needs to be soldered
Programming the Pico
