Portsdown Noise Meter
Revision as of 19:01, 27 April 2024 by G8GKQ (talk | contribs)
The Portsdown Noise Level Meter uses a LimeSDR or a Pluto SDR to measure and indicate noise or carrier power levels. It has 4 modes:
  • Absolute Noise Measurement
  • Differential Noise Measurement
  • Carrier Level Measurement with reference to noise
  • Absolute Carrier Level Measurement
Absolute noise measurement is used to measure Sun or Moon noise. The system can be "zeroed" against cold sky, and then the meter will indicate the increase in noise averaged over a wide bandwidth. Differential noise measurement can be used to measure the strength of DATV transmissions or possibly to optimise aerial/receiver matching. The noise power in a reference (quiet) frequency range is measured and compared with the noise power in a frequency range that contains a DATV signal. The Carrier Level measurement can compares the peak level of a carrier within a defined frequency range with the average noise level in a quiet frequency range otr just measure the absolute level of the carrier.
The Noise Level Meter is selected from Menu 2, Test Equipment. Web view and web control is implemented for the Noise Level Meter.
On starting the meter, select the frequency and bandwidth required. Connect the receiver or preamp to the input of the SDR and, on the setup menu, adjust the Gain so that the noise level is around -60 dB (Lime) or 50 db (Pluto). Background noise levels below this are outside the linear range of measurement. Press the "Establish Baseline" button and the meter should read near zero. Any increases in noise from the baseline level will then register on the meter. The spectrum plot allows interfering signals that may upset the reading to be seen. The "DC spike" in the centre of the spectrum is rejected from the calculations.
The meter scale can be changed through 6 ranges by touching the right and left sides of the meter face. The ranges are
  • 0 to 30 dB (default)
  • 20 to 30 dB
  • 10 to 20 dB
  • 0 to 10 dB
  • 0 to 5 dB
  • -5 to +5 dB
The meter reading is recorded on the history chart. The default length of the history is 100 seconds. This can be changed from the 2nd Config Menu (select Freq and Bandwidth, Config Menu, More Config). The smoothing time for the noise reading can also be adjusted here.
The differential noise measurement mode is selected from the Mode Menu and compares the noise level in 2 frequency ranges.
The frequency ranges are indicated by the shaded areas and can be adjusted from the Config Menu. The adjustment figures are percentages of the span width.
Carrier Level Measurement with reference to Noise
Carrier/Noise level mode is selected from the Mode Menu. Again, the average level of noise in one frequency range is used as the reference. However, the peak level of the strongest signal in the second frequency range is used for comparison. With no carrier, it is comparing peak noise with average noise, so the reading will be about 2.5 dB.
The position of the peak is indicated by a green line. The time smoothing is automatically increased in this mode to obtain a stable reading suitable for use in the optimisation of systems.
"Carrier Abs Level" is selected from the Mode menu. The baseline level for the meter reading can be set in the Set-up Menu. The default is -80.0 dB, but it can be increased if strong signals need to be measured.
For the carrier meausement modes, a "Flat Top" windowing function is used to measure the peak amplitude, which provides an almost constant reading across 2 fft "bins". While this is good for stability, there is a 4 dB reduction in apparent sensitivity compared to the Hanning windowing function used in the absolute and differential noise measurement modes.
