PicoTuner Ethernet Interface
Revision as of 09:02, 23 July 2024 by G4EWJ (talk | contribs)
In progress . . .
When the standard USB connected PicoTuner is replaced by a WIZnet W5100S-EVB-Pico or W5500-EVB-Pico module, this provides two receivers which can be controlled over the Ethernet connection and can send the received transport streams via the Ethernet connection, similar to a WinterHill.
Overview
There is no transport sream transfer by USB. A USB connection is not required.
This software is compatible with OpenTuner (0.B).
Finding the IP Address
LNB PSU Output
Software Loading
Connect the USB port to a PC.
Quick Start
Connect an Ethernet cable.
