PicoTuner Ethernet Interface
Revision as of 09:48, 23 July 2024 by G4EWJ (talk | contribs)
In progress . . .
When the standard USB connected PicoTuner is replaced by a WIZnet W5100S-EVB-Pico or W5500-EVB-Pico module, this provides two receivers which can be controlled over the Ethernet connection and can send the received transport streams via the Ethernet connection, similar to a WinterHill.
Quick Start
Connect an Ethernet cable.
Overview
There is no transport sream transfer by USB. A USB connection is not required.
This software is compatible with OpenTuner (0.B).
Finding the IP Address
LNB PSU Output
Software Loading
Connect the USB port to a PC.
Required Equipment
Basic Operation
Parameters
The Base IP Port is 9900.
Working with a WinterHill
Ethernet MAC and Host Name
E.g. 28:CD:C1:41:97:2E
E.g. PicoTunerWH-41972E
DHCP
An IP address must be obtained at startup. After this, the Ethernet cable can be unplugged and plugged.
USB Serial Port Connection
On a PC:
On an RPi:
Type:
dmesg
to give a display similar to below.
Type:
You may need to retry when doing this after startup, if you try it too soon. The Putty font size may need to be reduced to fit the data - try 11 point:
