PicoTuner Ethernet Interface
In progress . . .
When the standard USB connected PicoTuner is replaced by a WIZnet W5100S-EVB-Pico or W5500-EVB-Pico module, this provides two receivers which can be controlled over the Ethernet connection and can send the received transport streams via the Ethernet connection, similar to a WinterHill.
Quick Start
Connect an Ethernet cable.
Overview
This software is compatible with OpenTuner (0.B).
Finding the IP Address
LNB PSU Output
Software Loading
Connect the USB port to a PC.
Required Equipment
Basic Operation
Parameters
The Base IP Port is 9900.
Working with a WinterHill
Ethernet MAC and Host Name
- E.g. 28:CD:C1:41:97:2E
- E.g. PicoTunerWH-41972E
DHCP
An IP address must be obtained at startup. After this, the Ethernet cable can be unplugged and plugged.
USB Serial Port Connection
On a PC:
- use Device Manager to find the COM port that has been allocated
On an RPi:
- Type:
- dmesg
- Type:
- to give a display similar to below.
Type:
Type:
Enter a new line:
Replace the serial number and tty name with your own.
Save and exit
- CTRL-X then Y then ENTER.
Uplug and plug the Pico.
Type:
- ls /dev
to check that ttyPT0 appears.
The command to connect to the USB serial port will now be:
On a PC, find the COM port number with Device Manager and open a serial connection at 1200 baud with putty and then close it. The Pico virtual disk drive should now appear and the .uf2 file can be dragged onto it.
On an RPi, find the ttyACM port that the Pico appears as and type:
Broadcast Packet on Port 9997
======================================= PicoTuner Broadcast --------------------------------------- Sequence 105 Run time 112s Broadcast port 9997 Pico serial E6623C3767182B31 Net hardware WIZnet W5500 MAC 28:CD:C1:18:2B:31 Host name PicoTunerWH-182B31 DHCP state Success Lease remaining 3495s IP address 192.168.77.163 NIM type FTS4334L LNB supply X HI LNB supply Y absent Software ptwh0v3b-w5500.uf2 Mode WinterHill Base IP port 9900 RX1 10496.708 PE1FWC RX2 10498.220 F5DB TS target RX1 192.168.77.247:9941 TS target RX2 192.168.77.247:9942 =======================================
- netcat -kluvw 0 9997
