PicoTuner Ethernet Interface
In progress . . .
When the standard USB connected PicoTuner is replaced by a WIZnet W5100S-EVB-Pico or W5500-EVB-Pico module, this provides two receivers which can be controlled over the Ethernet connection and can send the received transport streams via the Ethernet connection, similar to a WinterHill.
Quick Start
Connect an Ethernet cable.
Overview
Finding the IP Address
LNB PSU Output
Software Loading
Connect the USB port to a PC.
Required Equipment
Basic Operation
Parameters
The Base IP Port is 9900.
Working with a WinterHill
Ethernet MAC and Host Name
E.g. 28:CD:C1:41:97:2E
E.g. PicoTunerWH-41972E
DHCP
An IP address must be obtained at startup. After this, the Ethernet cable can be unplugged and plugged.
USB Serial Port Connection
On a PC:
On an RPi:
Type:
dmesg
to give a display similar to below.
Type:
Type:
Enter a new line:
Replace the serial number and tty name with your own.
Save and exit
CTRL-X then Y then ENTER.
Uplug and plug the Pico.
Type:
ls /dev
to check that ttyPT0 appears.
The command to connect to the USB serial port will now be:
On a PC, find the COM port number with Device Manager and open a serial connection at 1200 baud with putty and then close it. The Pico virtual disk drive should now appear and the .uf2 file can be dragged onto it.
On an RPi, find the ttyACM port that the Pico appears as and type:
Broadcast Packet on Port 9997
       PicoTuner Broadcast
       Sequence   105
       Run time   112s
 Broadcast port   9997
   Net hardware   WIZnet W5500
            MAC   28:CD:C1:18:2B:31
     DHCP state   Success
Lease remaining   3495s
     IP address   192.168.77.163
       NIM type   FTS4334L
   LNB supply X   HI
   LNB supply Y   absent
       Software   ptwh0v3b-w5500.uf2
           Mode   WinterHill
   Base IP port   9900
            RX1   10496.708 PE1FWC
            RX2   10498.220 F5DB
netcat -kluvw 0 9997
