PicoTuner Ethernet Interface
In progress . . .
Quick Start
Connect an Ethernet cable.
Overview
Finding the IP Address
LNB PSU Output
Software Loading
Connect the USB port to a PC.
Required Equipment
Basic Operation
The Base IP Port is 9900.
Working with a WinterHill
Ethernet MAC and Host Name
E.g. 28:CD:C1:41:97:2E
E.g. PicoTunerWH-41972E
DHCP
USB Serial Port Connection
On a PC:
On an RPi:
Type:
dmesg
Type:
Type:
Enter a new line:
Save and exit
CTRL-X then Y then ENTER.
Uplug and plug the Pico.
Type:
ls /dev
to check that ttyPT0 appears.
On a PC:
On an RPi:
Broadcast Packet on Port 9997
       PicoTuner Broadcast
       Sequence   105
       Run time   112s
 Broadcast port   9997
   Net hardware   WIZnet W5500
            MAC   28:CD:C1:18:2B:31
     DHCP state   Success
Lease remaining   3495s
     IP address   192.168.77.163
       NIM type   FTS4334L
   LNB supply X   HI
   LNB supply Y   absent
       Software   ptwh0v3b-w5500.uf2
           Mode   WinterHill
   Base IP port   9900
            RX1   10496.708 PE1FWC
            RX2   10498.220 F5DB
netcat -kluvw 0 9997
Change the Base IP Port: [to@wh] bip=9908 change the Base IP Port and reboot
Change activity LED action: [to@wh] tsflash=0 activity LEDs are steady on when receiving, otherwise off
Tuning commands can be sent in MinTioune format, as used by M0DTS's QuickTune program for QO-100. https://github.com/m0dts/QO-100-WB-Live-Tune/releases
Remote tuning commands may be sent in WinterHill format o port 9920 using UDP, when the Base IP Port is 99xx. Case is not important.
[to@wh] rcv=10 freq=10491500 offset=9750000 srate=1500 vgx=hi (the LNB voltage command is optional - the parameter is OFF,LO,HI,LOT, HIT)
