PicoTuner Ethernet Interface
In progress . . .
Quick Start
Connect an Ethernet cable.
whpcrxcom (on the BATC WinterHill wiki) can be used to send receive commands. WinterHill Receiver Project#PC Software
Overview
Finding the IP Address
LNB PSU Output
Second LNB PSU Output
Software Loading
Connect the USB port to a PC.
Required Equipment
Basic Operation
The Base IP Port is 9900.
Working with a WinterHill
Ethernet MAC and Host Name
- E.g. 28:CD:C1:41:97:2E
- E.g. PicoTunerWH-41972E
DHCP
USB Serial Port Connection
On a PC:
- use Device Manager to find the COM port that has been allocated
On an RPi:
- Type:
- dmesg
- Type:
Type:
Type:
Enter a new line:
Save and exit
- CTRL-X then Y then ENTER.
Uplug and plug the Pico.
Type:
- ls /dev
On a PC:
On an RPi:
- find the ttyACM port that the Pico appears as and type:
Broadcast Packet on Port 9997
PicoTuner Broadcast
Sequence 105
Run time 112s
Broadcast port 9997
Pico serial E6623C3767182B31
Net hardware WIZnet W5500
MAC 28:CD:C1:18:2B:31
Host name PicoTunerWH-182B31
DHCP state Success
Lease remaining 3495s
IP address 192.168.77.163
NIM type FTS4334L
LNB supply X HI
LNB supply Y absent
Software ptwh0v3b-w5500.uf2
Mode WinterHill
Base IP port 9900
RX1 10496.708 PE1FWC
RX2 10498.220 F5DB
TS target RX1 192.168.77.247:9941
TS target RX2 192.168.77.247:9942
- netcat -kluvw 0 9997
| Reset: | [to@wh] reset=147 | clear any remote settings and reboot |
| Reboot: | [to@wh] reboot=258 | reboot, but do not clear any remote settings |
| BOOTSEL: | [ to@wh] bootsel=369 | go into software upload mode |
| Change the Base IP Port: | [to@wh] bip=9908 | change the Base IP Port and reboot |
| Change activity LED action: | [to@wh] tsflash=0 | activity LEDs are steady on when receiving, otherwise off |
- echo "[to@wh] bip=9908 tsflash=0" | netcat -uw1 192.168.77.204 9920 using the IP address of your PicoTunerWH
- [to@wh] rcv=10 freq=10491500 offset=9750000 srate=1500 vgx=hi (the LNB voltage command is optional - the parameter is OFF,LO,HI,LOT, HIT)
To do this from an RPi, type:
- echo "[to@wh] rcv=10 freq=10491500 offset=9750000 srate=1500 vgx=hi | netcat -uw1 192.168.77.204 9920 using the IP address of your PicoTunerWH
