PicoTuner Ethernet Interface
In progress . . .
Quick Start
Connect an Ethernet cable.
Use WinterHill utilities or OpenTuner 0.B for control and viewing.
Overview
Finding the IP Address
LNB PSU Output
Second LNB PSU Output
Software Loading
Connect the USB port to a PC.
After the software has been loaded, the Pico can be put into BOOTSEL mode without having to press the Pico buttons. Getting Into Software Upload Mode
Required Equipment
Basic Operation
The Base IP Port is 9900.
Working with a WinterHill
Ethernet MAC and Host Name
- E.g. 28:CD:C1:41:97:2E
- E.g. PicoTunerWH-41972E
DHCP
USB Serial Port Connection
On a PC:
- use Device Manager to find the COM port that has been allocated
On an RPi:
- Type:
- dmesg
- Type:
Type:
Type:
Enter a new line:
Save and exit
- CTRL-X then Y then ENTER
Uplug and plug the Pico.
Type:
- ls /dev
On a PC:
On an RPi:
- find the ttyACM port that the Pico appears as and type:
Broadcast Packet on Port 9997
PicoTuner Broadcast
Sequence 105
Run time 112s
Broadcast port 9997
Pico serial E6623C3767182B31
Net hardware WIZnet W5500
MAC 28:CD:C1:18:2B:31
Host name PicoTunerWH-182B31
DHCP state Success
Lease remaining 3495s
IP address 192.168.77.163
NIM type FTS4334L
LNB supply X HI
LNB supply Y absent
Software ptwh0v3b-w5500.uf2
Mode WinterHill
Base IP port 9900
RX1 10496.708 PE1FWC
RX2 10498.220 F5DB
TS target RX1 192.168.77.247:9941
TS target RX2 192.168.77.247:9942
- netcat -kluvw 0 9997
| Reset: | [to@wh] reset=147 | clear any remote settings and reboot |
| Reboot: | [to@wh] reboot=258 | reboot, but do not clear any remote settings |
| BOOTSEL: | [ to@wh] bootsel=369 | go into software upload mode |
| Base IP Port: | [to@wh] bip=9908 | change the Base IP Port and reboot |
| Activity LED action: | [to@wh] tsflash=0 | activity LEDs are steady on when receiving, otherwise off |
- echo "[to@wh] bip=9908 tsflash=0" | netcat -uw1 192.168.77.204 9920 using the IP address of your PicoTunerWH
- [to@wh] rcv=9 freq=10491500 offset=9750000 srate=1500 vgx=hi (the LNB voltage generator command is optional - the parameter is OFF,LO,HI,LOT, HIT)
- [to@wh] rcv=10 freq=1304000 offset=0 srate=4000 vgy=lot (a second voltage generator could be fitted manually)
To do this from an RPi, type:
- echo "[to@wh] rcv=9 freq=10491500 offset=9750000 srate=1500 vgx=hi" | netcat -uw1 192.168.77.204 9920 using the IP address of your PicoTunerWH
