PicoTuner Ethernet Interface
******* In progress. The software will appear here when it is ready for release. *******
PicoTuneWH is software for the BATC PicoTuner.
OpenTuner 0.B may also be used, using the Ethernet connection. https://www.zr6tg.co.za/open-tuner/
Quick Start
Connect an Ethernet cable.
Overview
Required Equipment
Software Loading
Connect the USB port to a PC.
Basic Operation
The Base IP Port is 9900.
Finding the IP Address
Ethernet MAC and Host Name
- E.g. 28:CD:C1:41:97:2E
- E.g. PicoTunerWH-41972E
DHCP
LNB PSU Output
Second LNB PSU Output
Working with a WinterHill
After startup, the first receiver is set to the QO-100 beacon and does the calibration.
Two seconds later, the second receiver is set to the beacon.
USB Serial Port Connection
On a PC:
- use Device Manager to find the COM port that has been allocated.
On an RPi:
- Type:
- ls /dev
- Type:
- Type:
- dmesg
- Type:
Type:
Type:
Add a new line:
Replace the serial number with your own. Replace the tty name with your own choice.
Save and exit
- CTRL-X then Y then ENTER
Uplug and plug the Pico.
Type:
- ls /dev
On a PC:
On an RPi:
- find the ttyACM port that the Pico appears as and type:
Broadcast Packet on Port 9997
======================================= PicoTuner Broadcast --------------------------------------- Sequence 1294 Run time 1301s Broadcast port 9997 Pico serial E6623C3767449A2E Net hardware WIZnet W5500 MAC 28:CD:C1:44:9A:2E Host name PicoTunerWH-449A2E DHCP state Success Lease remaining 2305s IP address 192.168.77.196 NIM type FTS4334L LNB supply X HI LNB supply Y absent Software ptwh0v3c-w5500.uf2 Mode WinterHill Base IP port 9904 RX5 10496.700T DD0CW RX6 10491.501T A71A TS target RX5 192.168.77.247:9945 TS target RX6 192.168.77.247:9946 =======================================
- netcat -kluvw 0 9997
Windows does not seem to have an inbuilt equivalent of netcat, but this very old utility works OK. https://github.com/cyberisltd/NcatPortable
Type:
- ncat -luv 9997
Reset: | [to@wh] reset=147 | clear any remote settings and reboot |
Reboot: | [to@wh] reboot=258 | reboot, but do not clear any remote settings |
BOOTSEL: | [ to@wh] bootsel=369 | go into software upload mode |
Base IP Port: | [to@wh] bip=9908 | change the Base IP Port and reboot |
Activity LED action: | [to@wh] tsflash=0 | activity LEDs are steady on when receiving, otherwise off |
- echo "[to@wh] bip=9908 tsflash=0" | netcat -uw1 192.168.77.196 9920 using the IP address of your PicoTunerWH
- echo [to@wh] bip=9908 tsflash=0 | ncat -uvi1 192.168.77.196 9920
The command must contain: rcv, freq, offset, srate, fplug (5 parameters and optionally vgx / vgy) OR ONLY vgx / vgy.
- [to@wh] rcv=5 freq=10491500 offset=9750000 srate=1500 fplug=A (the LNB voltage generator command is optional - the parameter is OFF,LO,HI,LOT, HIT)
- [to@wh] rcv=6, freq=1304000, offset=0, srate=4000, fplug=A, VGX=HI
- [to@wh] VGX=LOT
To do this from an RPi, type:
- echo "[to@wh] rcv=5 freq=10491500 offset=9750000 srate=1500 fplug=A vgx=hi" | netcat -uw1 192.168.77.196 9920
- echo [to@wh] rcv=5 freq=10491500 offset=9750000 srate=1500 fplug=A vgx=hi | ncat -uvi1 192.168.77.196 9920
