PicoTuner Ethernet Interface
Revision as of 16:52, 5 December 2024 by G4EWJ (talk | contribs)
Updates, News and Issues
The latest information will appear in this section. Please post any questions or problems on the BATC forum: https://forum.batc.org.uk/viewtopic.php?f=15&t=8934
Quick Start
Connect an Ethernet cable.
Overview
Required Equipment
Software Loading
Connect the USB port to a PC.
Basic Operation
The Base IP Port is 9900.
If you already have a WinterHill, the Base IP Port can be changed to be 9904 at power up. This provides receivers 5 and 6.
On the 10 pin GPIO header, connect pin 8 counting from the right (GP28) marked 28, to pin 10 (GND) marked G. Alternatively, put a jumper on Pico pins 33-34 (grounding GP28). Reboot.
Finding the IP Address
Ethernet MAC and Host Name
E.g. 28:CD:C1:41:97:2E
E.g. PicoTunerWH-41972E
DHCP
LNB PSU Output
Second LNB PSU Output
Working with a WinterHill
USB Serial Port Connection
On a PC:
On an RPi:
Type:
ls /dev
Type:
dmesg
Type:
Type:
Add a new line:
Save and exit
CTRL-X then Y then ENTER
Uplug and plug the PicoTuner.
Type:
ls /dev
to check that ttyPT0 appears.
On a PC:
On an RPi:
       PicoTuner Broadcast
       Sequence   1294
       Run time   1301s
 Broadcast port   9997
   Net hardware   WIZnet W5500
            MAC   28:CD:C1:44:9A:2E
     DHCP state   Success
Lease remaining   2305s
     IP address   192.168.77.196
       NIM type   FTS4334L
   LNB supply X   HI
   LNB supply Y   absent
       Software   ptwh0v3e-w5500.uf2
           Mode   WinterHill
   Base IP port   9904
            RX5   10496.700T DD0CW
            RX6   10491.501T A71A
netcat -kluv 9997
In a Command Box, type:
ncat -luv 9997
[to@wh] VGX=LOT
To do this from an RPi, type:
Waiting for Ethernet link - 0
Waiting for Ethernet link - 1
DHCP: starting
DHCP: waiting for OFFER
DHCP: REQUEST sent
DHCP: waiting for ACK
DHCP: ACK received
DHCP: +++ SUCCESS +++
