Portsdown 5 GPIO Connections
List of GPIO connections
Pin No BCM No Wiring Pi RPi Pri RPi Alt0 Primary Use Secondary Use Notes & GPIO breakout board connections
1 - - 3.3v - - - -
2 - - 5v - - - -
3 2 8 GPIO 2 SDA1 I2C Control - -
4 - - 5v - - - -
5 3 9 GPIO 3 SCL1 I2C Control - -
6 - - 0v - - - -
7 4 7 GPIO 4 GPCLK0 Load Switch - -
8 14 15 GPIO 14 TXD0 - - -
9 - - 0v - - - -
10 15 16 GPIO 15 RXD0 - - -
11 17 0 GPIO 17 FL1 - - -
12 18 1 GPIO 18 SPI6_CE0_N - - -
13 27 2 GPIO 27 SD0_DAT3 "Active" LED - -
14 - - 0v - - - -
15 22 3 GPIO 22 SD0_CLK Shutdown Button - Active high
16 23 4 GPIO 23 SD0_CMD - - -
17 - - 3.3v - - - -
18 24 5 GPIO 24 SD0_DAT0 DMM Serial in - -
19 10 12 GPIO 10 SPI0_MOSI MCP3002 - -
20 - - 0v - - - -
21 9 13 GPIO 9 SPI0_MISO MCP3002 - -
22 25 6 GPIO 25 SD0_DAT1 - (SA Sweep Blank in) -
23 11 14 GPIO 11 SPI0_SCLK MCP3002 - -
24 8 10 GPIO 8 SPI0_CE0_N CE for MCP3002 - -
25 - - 0v - - - -
26 7 11 GPIO 7 SPI0_CE1_N - Noise source -
27 0 30 ID_SD SDA0 - - DO NOT CONNECT
28 1 31 ID_SC SCL0 - - DO NOT CONNECT
29 5 21 GPIO 5 GPCLK0 spi clock - -
30 - - 0v - - - -
31 6 22 GPIO 6 GPCLK2 spi data - -
32 12 26 GPIO 12 PWM0 - - -
33 13 23 GPIO 13 PWM1 - - -
34 - - 0v - - - -
35 19 24 GPIO 19 SPI6_MESO - - -
36 16 27 GPIO 16 FL0 - - -
37 26 25 GPIO 26 SD0_DAT2 - - -
38 20 28 GPIO 20 SPI6_MOSI - - -
39 - - 0v - - - -
40 21 29 GPIO 21 SPI6_SCLK TX LED/PTT Drive out - -
