HAMTV from the ISS - HAMTV Transmitter Information
Whilst the transmitter has a number of possible configurations, it is anticipated that most transmissions will be:
- RF: 2395 MHz, RHCP.
- Modulation: 2.0 Msymbols/second, QPSK, DVB-S, FEC 1/2
- Content: MPEG-2 video with MP2 audio.
Other possible frequencies are:
- 2369 MHz
- 2422 MHz
- 2437 MHz
Polarisation is RHCP.
DVB-S modulation
- FEC : ½
- Rolloff: 35%
TS format
- MPEG-2 Video, approx. 1.5 Mbits/s, PID 256
- MP2 Audio, approx 64kb/s, PID 257
- Null padding, PID 8191
- NTSC
ISS HAMTV antenna
The HamTV transmission runs relatively low power on 2395MHz to antenna 41 on the ISS which is a simple patch antenna.
