HAMTV from the ISS - HAMTV Transmitter Information
Whilst the transmitter has a number of possible configurations, it is anticipated that most transmissions will be:
  • RF: 2395 MHz, RHCP.
  • Modulation: 2.0 Msymbols/second, QPSK, DVB-S, FEC 1/2
  • Content: MPEG-2 video with MP2 audio.
Other possible frequencies are:
  • 2369 MHz
  • 2422 MHz
  • 2437 MHz
Polarisation is RHCP.
DVB-S modulation
  • FEC : ½
  • Rolloff: 35%
TS format
  • MPEG-2 Video, approx. 1.5 Mbits/s, PID 256
  • MP2 Audio, approx 64kb/s, PID 257
  • Null padding, PID 8191
  • NTSC
ISS HAMTV antenna
The HamTV transmission runs relatively low power on 2395MHz to antenna 41 on the ISS which is a simple patch antenna.
