Revision as of 09:51, 4 October 2025 by G4eml (talk | contribs) (Remove reference to ethernet adaptor. No longer relevent.)
When supported by the host software this then allows the reception of two signals at the same time. Dual channel support is available with the OpenTuner software.
PCB :- These will be available from the BATC shop, or you can get your own made using one of the Chinese PCB manufacturers. The Gerber files are available here https://github.com/g4eml/PicoTuner/tree/main/Adaptor
Raspberry Pi Pico :- Surface mount version without pin headers.
The Pi Hut Part Number:- SC0915 Mouser Part Number :- 358-SC0915
Harwin Part Number:- M20-8761346 Mouser Part Number:- 855-M20-8761346 Farnell Part Number :- 3756209
Harwin Part Number:- M20-9990545 Mouser Part Number:- 855-M20-9990545 Farnell Part Number :- 1022252
Assembly Instructions
Lay the pico board directly onto the PCB and align the edges with the pads. Apply solder to the castelated edge of pin 1 to form a fillet of solder. Check the alignment of the board and adjust as necessary. When happy apply solder to all castellated holes.
Connect J1 Pin 1 to D7
Connect J1 pin 2 to CLK
Connect J1 pin 3 to VA
The three connection pads T, R and G on the adaptor board can also optionally be wired to 2 LEDs. These LEDS will then light to indicate activity on TS1 and TS2.
Programming the Pico
