Audio Subsystem
Revision as of 17:30, 19 November 2025 by G8GKQ (talk | contribs) (→‎Audio Devices)
Audio Volume Control
There are 2 ways of controlling the audio output volume on a Portsdown 5. The first is the "Master" volume, and the second is the application volume".
Audio Devices
The following audio devices are supported by default
  • The standard Portsdown white audio dongle
  • HDMI audio
Custom audio devices can be added, but the audio device name must be entered on the System Config menu first. To find the name of an audio device, log in to the command line, and with the device connected, enter "aplay -L". Look for the lines referring to your device that are similar to this:
hw:CARD=UACDemoV10,DEV=0
    UACDemoV1.0, USB Audio
    Direct hardware device without any conversions
The text required in this example is UACDemoV10 from the first line: hw:CARD=UACDemoV10,DEV=0. Go to Config Menu, System Config, Custom Audio Out Device and replace not_set with the exact text for your device (case sensitive). After entering it, you should see that the "Audio Out" button has changed to show your device name.
