Stream Viewer
Jump to navigation
Jump to search
This page is only applicable to the Portsdown 5, not the Portsdown 4 or Portsdown 2020.
The Stream Viewer is selected from the main menu and up to 20 BATC streams can be programmed as presets. Each button can be customised by pressing the "Amend Preset" button and then the button to be changed. Then enter the stream name (in lower case) and the button label (mormally the stream name but in upper case).
Players
VLC is the player for normal use, although FFPlay can be selected if desired. VLC has the advantage of an on-screen volume control.
