The Muntjac SDR
The Muntjac SDR was designed by Brian G4EWJ based on the same chip as the commercially-available Caribou SDR. The Muntjac uses a RP2040 micro-controller to provide a USB interface to the Portsdown 4.
Specifications
When used with the Portsdown 4, the Muntjac will transmit QPSK with symbol rates of 125 kS to 1000 kS. It will also transmit 8PSK with symbol rates of 125 kS to 500 kS. It will not transmit at higher symbol rates because the RP2040 USB 1.1 interface is limited to a bus speed of 12 Mbit/sec.
