The Muntjac SDR
Revision as of 19:56, 20 December 2025 by G8GKQ (talk | contribs)
The Muntjac SDR was designed by Brian G4EWJ based on the same chip as the commercially-available Caribou SDR. The Muntjac uses a RP2040 micro-controller to provide a USB interface to the Portsdown 4.
Specifications
When used with the Portsdown 4, the Muntjac will transmit QPSK with symbol rates of 125 kS to 1000 kS. It will also transmit 8PSK with symbol rates of 125 kS to 500 kS. It will not transmit at higher symbol rates because the RP2040 USB 1.1 interface is limited to a bus speed of 12 Mbit/sec.
Muntjac Performance
20 Example Example Example Example
19 Example Example Example Example
18 Example Example Example Example
17 Example Example Example Example
16 Example Example Example Example
15 Example Example Example Example
14 Example Example Example Example
13 Example Example Example Example
12 Example Example Example Example
11 Example Example Example Example
10 Example Example Example Example
