The Muntjac SDR
Revision as of 20:03, 20 December 2025 by G8GKQ (talk | contribs) (→Specifications)
The Muntjac SDR was designed by Brian G4EWJ based on the same chip as the commercially-available Caribou SDR. The Muntjac uses a RP2040 micro-controller to provide a USB interface to the Portsdown 4.
Specifications
When used with the Portsdown 4, the Muntjac will transmit QPSK with symbol rates of 125 kS to 1000 kS. It will also transmit 8PSK with symbol rates of 125 kS to 500 kS. It will not transmit at higher symbol rates because the RP2040 USB 1.1 interface is limited to a bus speed of 12 Mbit/sec.
Muntjac Performance
20 +5.6 dBm Example Example Example
19 +4.8 dBm Example Example Example
18 +4.0 dBm Example Example Example
17 +3.0 dBm Example Example Example
16 +2.1 dBm Example Example Example
15 +0.8 dBm -40 dB Example Example
14 +0.1 dBm Example Example
13 -0.9 dBm Example Example
12 -1.9 dBm Example Example
11 -2.6 dBm Example Example
10 -3.6 dBm -50 dB Example Example
9 -4.7 dBm Example Example
8 -5.7 dBm Example Example
7 -6.4 dBm Example Example
6 -7.4 dBm Example Example
5 -8.4 dBm < -50 dB Example Example
4 -9.4 dBm Example Example
3 -10.2 dBm Example Example
2 -11.2 dBm Example Example
1 -12.2 dBm Example Example
0 -13.2 dBm < -50 dB Example Example
