The Muntjac SDR
The Muntjac SDR was designed by Brian G4EWJ based on the same chip as the commercially-available Caribou SDR. The Muntjac is a transmit-only SDR for DATV that uses an RP2040 micro-controller to provide a USB interface to the Portsdown 4.
Specifications
When used with the Portsdown 4, the Muntjac will transmit QPSK with symbol rates of 125 kS to 1000 kS. It will also transmit 8PSK with symbol rates of 125 kS to 500 kS. It will not transmit at higher symbol rates because the RP2040 USB 1.1 interface is limited to a bus speed of 12 Mbit/sec.
Muntjac Performance
19 +4.8 dBm +3.7 dBm
18 +4.0 dBm +2.8 dBm
17 +3.0 dBm +2.1 dBm
16 +2.1 dBm +1.2 dBm
14 +0.1 dBm -0.5 dBm
13 -0.9 dBm -1.4 dBm
12 -1.9 dBm -2.5 dBm
11 -2.6 dBm -3.3 dBm
9 -4.7 dBm -5.3 dBm
8 -5.7 dBm -6.3 dBm
7 -6.4 dBm -7.3 dBm
6 -7.4 dBm -8.3 dBm
4 -9.4 dBm -10.3 dBm
3 -10.2 dBm -11.1 dBm
2 -11.2 dBm -12.1 dBm
1 -12.2 dBm -13.1 dBm
IQ Calibration of the Muntjac
Poor IQ calibration in an SDR can cause a carrier to be transmitted at the centre frequency of a DATV transmission. There is a file in the Portsdown build that contains an average set of calibration paramters. Should IQ calibration for a particular Muntjac be a problem this file (/home/pi/rpidatv/bin/muntjac.mjo) will need to be amended.
Programming the Muntjac
Muntjac SDRs are supplied with the correct program loaded in the RP2040. Should this need to be re-written, download this Zip file on a Windows PC and unzip it to get a .uf2 file File:muntjac4-0v1c.zip.
Press the BT (boot) button on the Muntjac whilst connecting it to the Windows PC by USB. A new disk drive labelled RPI-RP2 should appear on the PC; you can then release the button. Copy the .uf2 file into the RPI-RP2 drive. Once the file has copied, the disk drive will unmount. Disconnect the Muntjac from the Windows PC; it is ready for use with the Portsdown.
