Portsdown transmitter FAQ
Revision as of 21:03, 8 February 2026 by G4FRE (talk | contribs)
  • The Portsdown software update deoes not work
If you get the message "Unable to contact GitHub for update" "Internet connection to Google seems OK" when trying to perform a software update, it means that the Portsdown cannot download the new software due to a problem with your router or internet connection. The Portsdown can see Google so knows that it is connected to the internet. Check whether you can see this page on another computer on the same network: https://github.com/BritishAmateurTelevisionClub/portsdown4/raw/master/scripts/latest_version.txt
  • Why can't I download or update the software?
  • I've just changed my Callsign and now nothing works
If you have entered text with spaces in the callsign field, the software will crash (I've tried to cure this, but it's a very difficult problem). The cure is to open an SSH session (using Putty or Kitty), exit to the command line, and then do a factory reset by entering:
cp -f /home/pi/rpidatv/scripts/configs/portsdown_config.txt.factory /home/pi/rpidatv/scripts/portsdown_config.txt
If your software has not been updated since 1 February 2018, then the line that you should enter is:
cp -f /home/pi/rpidatv/scripts/configs/rpidatvconfig.txt.factory /home/pi/rpidatv/scripts/rpidatvconfig.txt
Afterwards, restart the console menu with the command:
  • How do I prevent regular clicks/thumps on Streamed audio?
Check the following: 1. A valid video signal must be present at the input to the EasyCap before you turn the streaming on. 2. The supply voltage, measured on the GPIO pins, should be between 5.0 and 5.1 volts during streaming. 3. The EasyCap should be plugged directly into the RPi or connected by a short, good quality, USB lead.
  • How do I reduce the background noise/hum on Streamed audio?
The poor quality USB leads supplied with the EasyCaps should not be used. The EasyCap should be plugged directly into the RPi or connected by a short, good quality, USB lead.
  • Why do I get occasional dropouts of the received or streamed picture at 16:9 or 720p?
The Raspberry Pi 3 is working at its processing limit at these higher resolutions and occasionally runs out of resources. 16:9 is particularly bad because it is generated by down-scaling 720p, or stretching SD.
  • Can I use the new Raspberry Pi 3+?
Yes. The "Portsdown 2020" software build works on a Raspberry Pi 3+ or a Raspberry Pi 3. Details here: https://github.com/BritishAmateurTelevisionClub/portsdown .
  • How do I turn the transmitter off in Touchscreen mode?
In transmit, the touchscreen is used to monitor outgoing video and so the buttons are no longer visible - to turn the transmitter off, simply touch the screen anywhere.
  • What do I need to receive a Portsdown transmitter?
When a Portsdown transmitter is fitted with a filter / modulator card and running in normal bandwidth modes (above 1 Msymbol/sec) you will be able receive it on any Free to Air (or FreeSat but not Sky or Freeview) satellite Set top box - if you have a High Definition STB you will be able to receive MPEG-2 and MPEG-4.
However, when it is running in RB-TV modes OR in Ugly mode without the Filter Modulator card, you can only receive it using the MiniTiouner USB receiver.  This is a BATC supported project with some home construction needed - the hardware components are available from the BATC shop and the software is a free download from F6DZP see here for more details.
  • Can I use another touchscreen LCD?
The Portsdown project only supports the 3.5" Waveshare screen - that doesn't mean to say others won't work but we can't help you if it doesn't. The Official Raspberry Pi 7" touchscreen (often referred to as a "7 inch Element 14 touchscreen") https://www.element14.com/community/docs/DOC-78156/l/raspberry-pi-7-touchscreen-display is the only recommended alternative. HDMI-connected touchscreens are not suitable.
  • Can I use a Raspberry Pi 2?
  • Who are the Portsdown team?
  • Do I need to know about Linux or other clever computer stuff to get Portsdown running?
  • Is Portsdown MPEG-2 or MPEG-4?
Both - The RPi hardware encoder runs MPEG-4 and the Portsdown software has an MPEG-2 encoder both of which are used in the Portsdown transmitter.
  • When I type my password, the cursor does not move. Is this right?
  • How do I get out of touch screen back in to console mode?
  • Connect the RPi to the same network as your PC, and either check on the touchscreen "info" page (on Menu 3) or use the IP Scanner to find the IP address of your RPi.
The console menu should start automatically and the touchscreen will display the BATC logo.
Note, if the console menu does not appear and you end up at the Linux Command Line, you can get back to the Main Console Menu by typing:
  • When I Log-on or start the Console Menu, it goes Straight to the Exit Screen. How do I recover?
If you accidentally enter a space character when entering the frequency or symbol rate, the Menu software fails and tries to exit. You can recover by typing the command:
at the Linux command line, and then restarting the console menu with the command:
  • How Can I update my Portsdown Software?
As long as you have an internet connection, you can update your Portsdown Software to the latest version from the Console Menu or the touchscreen Menu 3. Full instructions are here: Updating your Portsdown Software
  • Where can I get a diagram of all the RPi GPIO pins?
PTT and band switching#Summary_of_GPIO_connections
  • The lock LED on the ADF4351 board does not come on
The lock light only comes on when in Portsdown/IQ mode and you are on Transmit
